- This topic has 15 replies, 10 voices, and was last updated 1 year, 10 months ago by .
Following my triumphant win of the Christmas present competition, here’s a few notes on how I got on. Happy Christmas to me (from me) a Centaur 11s groupset. Sorry, I’m very late to this, I know this kit been out for a few year now.
Nicely boxed, but I can’t begin to describe how rubbish is the printed information you get with each component. Shimano’s isn’t perfect either, but this seems full of bad translations and witters on about when I should see a “specialised mechanic”. For example, I nearly had to look up which Allen bolt was which to adjust the H-L on the RD, although the C screw adjustment guidance was refreshingly clear.
I knew I’d have to change the freehub on my elderly Mavic Krysium R/W – that was a new job to me. But when I tightened up, either the smallest cog was only half on the freehub or when I removed the 10s spacer, the back of the 11s Centaur cassette jammed against the flange. So we’re back to a 11s Shimano cassette for now – compatible by some happenstance on the part of Mavic, Shimano and Campagnolo.
The brifter cable clamps needed backing off (which at least they tolerated without dropping to bits) x4 turns to mount them because of the shape of the plastic casing. Fitting the brake cables was pretty painless; shift cables were supplied installed, but I have no idea how I’d change them and there are no clues in the supplied instructions.
There were 5 silver ferrules supplied, clearly too small for the brake cable outer, but a loose fit on the shift cable – I thought a bit of compression was what reinforced the cable outers?
The biggest design difference as against Shimano is in the B/B and crankset. There’s no history of Campagnolo cranks falling apart, of course, but the decision to mount the bearings on the cranks seemed a strange one to me. With the open hollow crank ends and bearings located right in the extremes pretty exposed, I’m glad this is a fair weather bike.
Owners will know this, but Campag have addressed the vexed issue of compressing and attaching a crank to the axle by giving each crank half each – they mesh and soundly bolt together in the middle.
The Record B/B cups are simply that, but the spring-clip needed for the R/H cup suggests a design fail being swerved pretty coarsely.
It looked like on Park Tools you can screwdriver off the bearing circlip and use a bike-sized bearing puller, but you would need a (dedicated?) hollow punch to install a new one. My old-style Shimano B/B cup tool fitted.
The chain has got of those snap-off joining pins (that Shimano have stopped doing), so we’re on KMC until I can save £180 (for real?) up for the recommended tool. My chain tool includes a clamp on the far side, I assume it will to the job?
