Saddle without nose ?
  • This topic has 17 replies, 9 voices, and was last updated 6 years ago by mtbtomo.
  • #31081
    Capablanca
    Hello!
    In spring i bought myself a new Fabric Line-S line-up saddle.
    And i`m pretty happy with it`s cutout and overall width. It helps me to sit on my very sit bones with no soft tissue involved.
    But i try to spend more time in aero postition and here, regardless of this saddle being overall short and soft-> i feel its nose pushing my pelvis. I dont like this sensation, though i dont feel any numbness or pain, its just this uncomfy pressure. And after i sit at anything else after bike – i steel feel my pelvis soft tissues were affected and “massaged” by that nose and i dont feel its healthy.
    Can you guys advice similar saddle, but which has more soft nose.
    I would like to buy something close to thriathlon – they have completely cut nose, but as i understand i`m not able to install such a saddle to a group-ride solo bike and enter a contest\race, am i right ?
Viewing 15 replies - 1 through 15 (of 17 total)
  • #969465
    mtbtomo
    I bought the Aeolus in 155
    I bought the Aeolus in 155 wide first – to try and get some sit bone comfort. (As I said, I actually had an undiagnosed fracture). It didn’t occur to me when I bought it that the Aeolus was particularly rounded side to side – I do prefer flatter saddles (favourite it Fabric Scoop Flat). I’ve also got a Bontrager Montrose on another bike which is a more usual 143(?) wide and that’s fine but not as comfy. So if the Aeolus is a rounded profile, it probably feels flat enough because i likely don’t need the full width?
    I bought the fabric line s in 155 for another bike after I’d bought the Aeolus. It was cheaper than the Aeolus and Aeolus’s seemed to be out of stock in 155 at that time.
    I use Fabric Scoop Flat, Prime Race Ti (which are around 140(ish) width) and also BBB Phalanx saddle (165 wide) currently on other bikes.
    #969463
    Is no-one going to ask “how does it smell?”
    laugh
    #969461
    #969459
    Capablanca
    Thank you for the info!
    What are your sitbones btw? Did you take 145 or 155 Aeolus?
    Wish you the best health! Hope you will never struggle of any pain bike or not-bike related, all the best to you!
    #969457
    Capablanca
    Thank you!
    Thank you!
    so Aeolus is somewhat close to Line-S in terms of softness?
    Also, which widh you recommend – 145 or 155?
    Line-S is 155 and it is not bended side-to-side in width, but Aeolus states to be curved when you look at saddle up-front, so maybe stickibg to 155 is a best.
    My sitbones are 115mm.
    What about you in all these terms?
    #969455
    IanEdward
    Actually sorry, I was being a
    Actually sorry, I was being a bit dishonest. My actual issue was a pain behind the scrotum which I now believe was caused by a tight hip flexor impinging upon the genito-femoral nerve. This has nothing to do with saddle choice as it actually comes around the side and front of the hip and not underneath.
    HOWEVER I did immediately notice the reduction in pressure where the nose of the saddle would have been when using the Aeolus, and this actually has relieved a lot of stress in my back as I am no longer ‘arching’ my back to take pressure off my perineum. So in general I am more comfortable on the bike.
    So, the Aeolus wasn’t actually the solution to my personal problem, but it definitely DID take pressure away from the perineum and is more comfortable because of it.
    I can’t compare padding softness unfortunately, I use good bibshorts (Rapha, Morvelo, Endura, Castelli) and typically quite hard saddles. I can’t say I’ve noticed if the Aeolus is softer or harder than any other.
    #969453
    Capablanca
    The second comment mentionin
    The second comment mentionin Aeolus! Nice.
    It may be a good fit for me, but cant tell without try.
    What was your saddle issue exactly btw ?
    Can you compare it`s padding softness with anything else?
    If you tried prologo dimension (standart) for example, for me it is too firm, as well as all the Fizik line-up -> they are equally firm no matter the curvenessflatness of model
    #969451
    Capablanca
    Yes, i`ve been and still am
    Yes, i`ve been and still am experimenting with saddle tilt and foreaft, but not quite satisfied with sensations.
    Thank you for the info, so i will try to stick to thriathlon saddle and will not afraid to be disqualified!
    #969449
    Capablanca
    Thank you very much for this
    Thank you very much for this info!
    #969447
    Capablanca
    Thank you for answer!
    Which model exactly do u have?
    Are you able to bend towards stem and position yourself at the saddle`s tip without feeling any pressure to pelvis soft tissue?
    #969445
    mtbtomo
    +1 for Bontrager Aeolus. Was
    +1 for Bontrager Aeolus. Was the saddle I’ve been riding with a (unbeknown until recently) broken pelvis, a real game changer comfort wise. I too have have recently bought a Fabric Line S, and it does have a similar profile front to rear, but the nose is a bit pointier.
    #969443
    Capablanca
    thank you very much ! i will
    thank you very much ! i will dive into those variants
    #969441
    TheBillder
    ISMs turn up on eBay
    ISMs turn up on eBay frequently, fetching £30-40 or so – and also copies for about £12 (not fakes as such, but certainly flattering through imitation). Might be another way to try the concept. If you do try the, er, homages, please let us know how you get on.
    The reviews of the Bontrager Aeolus are very positive and as IanEdward says, that’s another viable cheaper option.
    #969439
    IanEdward
    A Bontrager Aeolus might be
    A Bontrager Aeolus might be the cheapest place to start, a great wee saddle at £45 and virtually ‘noseless’ with a large central cut-out.
    Functionally I’m not even sure if the ISM saddles are really much different.
    You can demo ISM from Upgrade bikes, you pay for the saddle but then have 30 days to test it. I was reassured when I received my demo saddle as it was a bit mucky, they obviously expect the demo saddles to get used properly!
    As it is, the Aeolus solved my issue at 1/4 of the price of an ISM (and for less weight…) so I sent the ISM back un-tried.
    #969437
    roadrunner23
    ISM saddle sounds like the
    ISM saddle sounds like the way to go. I’ve got one and it works well but did take a bit of fiddling about to get the right position. From memory I think I needed to lower the saddle by about 4mm.
