Replacing/upgrade saddle
  • This topic has 6 replies, 7 voices, and was last updated 6 years ago by fincon1.
  • #31075
    Watt is love
    Hi!
    Last 5 years I have used a Specialized Avatar 155mm for my bike. But now it’s getting worn and it’s time to replace it.
    I’m comfortable on the saddle but would like my new saddle to have a larger cut out or being deeper to relive pressure. Padding could be about the same and a bit less.
    Saving some weight would be nice too.
    Any sugestions?
  • #969379
    fincon1
    james.bowman wrote:
    james.bowman wrote:
    Fabric saddles are always worth a look. Choose the model, shape, size and rail materials.
    +1 for these. Cheap as chips, and for me at least way more comfortable than the Fizik saddles that came as standard on two of my bikes.
    #969377
    Strathbean
    In my experience, whats comfy
    In my experience, whats comfy for one isn’t necessarily comfy for another. Try some out, its the only way to get one that works for you. Many manufacturers will send you out a test saddle (or at least they would pre-covid) and your local bike emporium will usually have a few to try out.
    Measure your sit bones, just need a bit of corrugated cardboard. Also find out if you prefer rounded or flatter shape, or somewhere in between.
    Personally I like prologo and currently using a dimension ndr, short, wide with a cut out and just a little bit of padding, it works great for me.
    Any saddle is only going to be as comfy as your shorts, make sure they fit right as well.
    #969375
    Greenhorn
    Brooks cambium c13 is
    Brooks cambium c13 is surprisingly good given the lack of any padding at all. They are pricy but I have tried a few now and find it just works. Difficult to recommend such a personal component but width seems to be a crucial factor.
    #969373
    Spangly Shiny
    Specialized Power Expert 155.
    Specialized Power Expert 155. The expert has a little more padding and is more forgiving than the S-Works. If your old Avatar was a good fit then stick with the same size
    #969371
    james.bowman
    #969369
    justDave
    I recently put a Selle Italia
    I recently put a Selle Italia SLR Boost Superflow on my road bike, after seeing a review on VeloNews (I think). These saddles come in a confusing array of versions – Boost signifies that it is a short saddle. I have the Endurance version, and it’s the best saddle I’ve tried. Around 220g, but lighter railed versions are available for those with deep pockets.
