Replacing a Ultegra 6700 rear hub with a 6800
  • This topic has 5 replies, 4 voices, and was last updated 6 years ago by David9694.
  • #31195
    propagandazoo
    Has anyone tried swapping out the whole hub on a Ultegra 6700 with a complete 6800 hub to make a 6700 rim and spoke 11 speed?
    The spoke length seems virtually identical.
  • #971903
    I did a new build with 6800s
    I did a new build with 6800s and found it hard to get the exact information as to the flange size – IIRC, it’s a couple of mm bigger than 6700 for which information is available e.g. on the edd calculator.
    #971901
    propagandazoo
    Looks interesting.
    Looks interesting.
    My best solution so far is just to use a RS500 rear wheel as it looks pretty much the same as WH-6700.
    That or buy a handbuilt wh-6800 with different rims. I’d make my own if I could find a rear 32 hole hub set… But cannot competitively source one.
    I don’t see the point, or the price, of the RS700 as the carbon is not making a significant decrease in weight… Maybe the bearings are better than rs500 but cannot find any info on that.
    #971895
    propagandazoo
    This is totally not possible.
    On closer inspection the hubs are not compatible.
    #971899
    VeloUSA
    You could save yourself a lot
    You could save yourself a lot off hassle swapping hubs by using an Edco (UK manufacturer) Monoblock 11 speed cassette on your 6700 hub. https://www.edco-wheels.co.uk/product/monoblock-cassettes/
    #971897
    Captain Badger
    Glad we could help ??
