- This topic has 7 replies, 3 voices, and was last updated 5 years, 11 months ago by .
My Shimano L04C Pads (for 105 R7070 brake calipers) have lasted 1,300 miles, 62 rides. I fitted them at the same time as Ultegra Ice Tech rotors.
Is that a “normal” wear rate for these pads? They’ve got to 1mm thickness.
I do live in a hilly part of the UK, so it’s either ascending or descending when I ride.Am I right in thinking Sintered should last longer than Resin pads?
If the wear rate is above average, can you recommend a more hard wearing set of pads from another company?Thank you.
