Junior gears on new shimano 12-speed groupsets
  • #31978
    NikolajGregoric
    I was wondering how to get the gears of the new groupsets from shimano (12-speed Ultegra or Dura Ace) to fit inside the junior regulation of gear rollout. For example the hardest gear cannot be more than 52-14.
    But I can’t find any 12-speed cassettes that have the smallest cog 14. Any suggestions?
    Thank you
  • #989657
    MiserableBastard
    As far as I can tell,
    SRAM makes a 10-36 12sp cassette. I’ve no idea if the spacing’s compatible, but with a single 37-tooth chainring that would yield a legal gear range. I’d be amazed if the 12sp Ultegra and Dura-Ace derailleurs couldn’t handle it, given how cautious Shimano always is about the nominal capability of their derailleurs.
    #989655
    MiserableBastard
    Liam Cahill wrote:
    fitting a 40T chainring is likely to leave the lad/lass struggling on the hills.
    They’d still potentially have a 40/34 (31-inch) low gear, which is lower than the 36/30 (32-inch) I’d expect someone with a double (52/36) chainset to use for racing, but I don’t race so may very well be talking out of my arse.
    #989653
    NikolajGregoric
    A friend of mine used a
    A friend of mine used a campagnolo 12 speed cassette with the new ultegra and said it works just fine.
    Do you think that’s ok?
    #989651
    alan sherman
    If racing abroad, and they
    If racing abroad, and they won’t let you block off only via the limit screws, then an alternative is to bench grind the teeth off the higher gear gogs!
    #989649
    Jimmy Ray Will
    Lol, someone’s a lucky boy /
    Lol, someone’s a lucky boy / girl….
    #989647
    Liam Cahill
    The only 12-speed junior
    The only 12-speed junior cassette I know about is a Campagnolo model made by Miche. I’m pretty sure UK comms allow you to simply lockout the mech at the 14T, but right now, if you have to have the full spread available, then smaller chainrings would be the way to go, though fitting a 40T chainring is likely to leave the lad/lass struggling on the hills.
    #989645
    MiserableBastard
    Fit a 40-tooth single
    Fit a 40-tooth single chainring?
