- This topic has 2 replies, 2 voices, and was last updated 5 years, 2 months ago by .
Slightly bamboozled with this one. I have a grx815 rear mechs which is one of the shadow tech ones along with the rest of the grx range and the CX-centricUltegra RX range.
When I’m removing the back wheel I always struggle because the chain wraps further around the little cog than it does on a normal mech and the top jockey wheel sits much further forward. Instead of pulling the wheel straight up as normal you usually have to jiggle it towards the seat post then up. I usually end up having to slide the chain off the cog with my fingers and shimmy it down between the frame dropout and the end of the thru axle.
Is it just me?
