- This topic has 2 replies, 3 voices, and was last updated 6 years, 1 month ago by .
Hi looking for some advice with an Ultegra R8000 front derailleur. It’s perfectly adjusted as per manual and then all of a sudden will start hitting the outer ring on up shifts. First time it did it I assumed I had a miss shift and bent the cage slightly so reindexed as a couldn’t see anything wrong. Fast forward a couple of rides and it did it again this time I assumed it had slipped so adjusted again and torqued the bolt on the hanger. It’s now done it again after a couple of rides. Anyone had anything similar?
