- This topic has 7 replies, 5 voices, and was last updated 6 years, 6 months ago by .
Evening all need some advice
Bike has just been for service had gear cables and chain replaced and brake pads
Have a shinamo 105 gearset
So was changing through the gears in first gear was still rattling
I thought I’ve got this and watched some you tube videos on indexing , stupidly I though let’s just go through the full tutorial on derailer placement etc
So I moved the derailer etc with the 2-3mm gap and then went to re attach the cable
The mechanic has cut it to length and god knows how to get the cable back on seems to short
How can I release some slack to get the cable back on should I even try or just bite the bullet and tell the mechanic I messed up
