Cube C62 size?
  • #1703673
    kirka
    Hi there! I’m looking to buy a 2016 Cube Litening C62 frame. I’m 182.5 cm tall with an inseam of 87 cm. The frame is a size 56. Does anyone know if it would fit me? Thanks.
  • #1730465
    john88
    With a height of 182.5 cm and an inseam of 87 cm, size 56 of the Cube Litening C:62 should most likely fit you. However, fit depends not only on height, so it’s worth checking the stack and reach of this particular frame and comparing them with your current bike.
