- This topic has 10 replies, 8 voices, and was last updated 2 years, 9 months ago by
mattw.
January 28, 2024 at 11:51 am #32785
FatAndFurious
Maybe it’s a case of “get what you pay for” but I am looking for some gym floor rubber tiling type solution to go under my indoor trainer setup that won’t break the bank.
For whatever reason, the floor of the upstairs room seems to resonate with a decent ‘thrum’ at certain power/rpm so i want to put some foam or rubber matting under the trainer. Prices for “made for purpose” products seem really high.
What cheaper solutions do you use?
mattw
There’s this sort of thing on
There’s this sort of thing on Amazon 1mx1m rubber crumb at ~£28 15mm thick. with free delivery.
Various prices and colour mixes for thicknesses from 10mm to 40mm (£27 to £180). 15mm is the price sweet spot, which feels to me to be a good compromise. Weighs 14kg.
https://www.amazon.co.uk/Ark-Mat-Rubber-Crumb-Floor/dp/B0973DJ97P/That should be thick enough and solid enough to insulate any thrumming rhythms and give firm support. You may also find different parts of your floor are more springy, depending on the structure of your house. If it has to be upstairs I think the best position would be across several floor joists close to a wall where they are stiffer (ie in the same orientation as the floor boards in a traditional upstairs floor structure). YMMV.
It also sounds like the type of thing that can be repurposed (eg under washer or even a non-slip mat in your shower or when you shower the dog) if you find it does not do the job.
I might be tempted to find something similar at 6×4, or buy two, to give a wider base + space for situps and pressups and floorwork if you ever want a change of routine. But it depends on your space available + budget.
It might be worth a direct phone call to the company in Devon to see if they have one that is exactly the right rectangular shape for you.
Let us know how you get on.
FatAndFurious
Many thanks for the full run
Many thanks for the full run down.
My setup is an upstairs room, normal house, with a direct drive smart trainer and road bike. I’m looking for vibration isolation under that setup, whilst not being squishy and letting the bike move about.
I won’t be dropping weights on it, and it doesn’t need to have the longevity or wear resistance that a commercial gym would need. It’s just for me. If i ever do get around to doing floor work, i can get hold of a decent yoga mat locally for not much money.
I’d pretty much settled on the thick dense rubber crumb type of tile, and these =are= expensive, at least when sold on “gyms r us” specialist sites. I was hoping that similar products were sold for different purposes more affordably. I hadn’t thought about the equestrian route, so will follow up on that.
I think i could get away with a single 1m x 1m tile, cut 60/40 and arranged in a T shape, trainer sat on the 60 slice, and the 40 slice under the bike and front wheel.
So if anyone knows where such things might be sold cheaper, write below!
mattw
OK. Here’s the whole
OK. Here’s the whole briefing from a gym part-owner. Probably goes wider than you need but hopefully useful.
You don’t say what your trainer setup is – do you mean a roller-trainer, or a rowing machine, weights, or for doing pressups and situps on?
Is it supposed to cushion your body, let you drop things, or provide a quiet base for a machine? How wobbly can it be?
Having setup a couple of crossfit gyms in the last decade, there are several options. There are similar ones (eg a thinner version of 3) that may meet your needs. Getting a good understanding of your needs is the most important thing.
1 – You can get lightweight coloured foam mats that go together like a jigsaw. Gyms short of money may use these for eg childrens’ areas or warm up areas where members do stretches and so on. These are dirt cheap and appear from time to time in Aldi Special Buys and so on. Often they will be 2ft x 2ft. These are soft but yielding and around 6-10mm thick.
Imo these are not suitable for a proper exercise floor and are not a firm base, through OK for a warm up stretching aream, and perhaps Yoga (but your sit bones may feel bruised). But they are cheap enough that you can try them then throw them away.
Example: https://www.amazon.co.uk/Grendle-Black-30-5-Interlocking-Foam/dp/B08K91QPZM
2 – You can get stuff that comes on rolls that is perhaps 3-6mm thick, often with a pattern of circles on it. Or sometimes finish like a hairy rubberised material.
We use these for walking and running around areas, and walkways between areas of 3, glued down. We then put option 3 for areas where people exercise on the floor or eg boxes, or where weights may be dropped.
These are not suitable for doing sit down or lie down exercises on, but are probably OK for eg running up and down, or doing bear crawls etc.
Example: https://www.ebay.co.uk/itm/125733699969
3 – Then there are thick rubber matts that are ~12-20mm thick, and come in 6ft x 4ft usually or 1m x 1m. Each one weighs about 25-35kg, and can take weights being dropped.
We use these single or double thickness depending. They are suitable for ground exercise such as situps, and for weights. They can be a good base for a machine.
You want this stuff to land on from height or for working upside down – eg pull up frame or hand stand press ups.
We were paying £40-50 in a good deal on 18-20mm 6ft x 4ft ones of these wholesale buying enough for a whole gym back in 2018. Still going strong in a busy gym. Thinner ones may be OK for machines.
Examples:
https://www.ebay.co.uk/itm/164495346317
https://rubber-gym-flooring.com/product/premium-gym-flooring-rubber-20mm-tiles-1m-x-1m/4 – How to buy.
a) The important physical things are degree of softness, density and thickness. Don’t let anyone sell you 1 as 2 or 2 as 3, or a thinner version as the real thing. That’s a false economy. Better to save up for the right stuff than risk injury.
b) Suggest you take up the free month membership at your local gym (suggest a Crossfit or similar gym as they have cycling sort of kit and do floor work), to learn about surfaces and work out what you need.
c) For 2 and 3 look for suppliers to gyms close to you to collect, or free delivery online with a 14-day return right. 2 and 3 are heavy and carriage can overwhelm cheap price. Amazon Prime free delivery may be useful.
d) When you know what you want have a word with a gym where you or family are a member and ask if they have anything in their storeroom, and can you have some if you make a suitaby generous donation to their gym charity.
e) Choose your sizes carefully; there are some exercises you do not want to do across joins if you are not gluing it down (which needs VERY good glue – eg Evostik Seriously Strong Stuff.).
f) 3 above is quite like horse stall matting. So visit your local equestrian / agricultural supplier for a look-see.All the best.
wycombewheeler
bobbinogs wrote:wycombewheeler wrote:Tom_77 wrote:You can get rubber feet and mats for washing machines, that should work.I found it hard to mount the bike when I put it on top of the washing machine.
Yeah, but the spin cycle makes it so, so worth it!
explains why spin classes are so much more popular with the ladies than cycling outdoors in the beautiful countryside.
bobbinogs
wycombewheeler
I have a £35 mat, like this:
I have a £22 mat, like this:
https://www.fitness-superstore.co.uk/body-power-48-x-36-floor-protector-mat.htmlIt’s different to a yoga type mat as it’s very heavy and doesn’t move around. Reduces sound and vibration a bit as well as protecting the floor.
They have a range of sizes…
https://www.fitness-superstore.co.uk/fitness-equipment/fitness-accessories/equipment-matskinderje
B&Q do interlocking rubber
B&Q do interlocking foam mats. Can’t remember the exact price but I think it was around £10 for four mats.
I’ve found a doubled over
I’ve found a doubled over yoga mat offers enough vibration absorption; if you keep an eye out as you ride around loads of people seem to leave them outside their houses for any takers, particularly this time of year – possibly indicative of new year resolutions falling by the wayside!
