Converting bolt axel to quick release
  • This topic has 3 replies, 2 voices, and was last updated 5 years ago by Pilot Pete.
  • #31824
    Theo32
    Hello,
    Thank you for welcoming me to your forum.
    I’m having trouble seeing if my front wheel needs a whole axel system, or does it need just the axel rod?? I’m going to eventually change my back wheel to quick release.
    I’ve purchased a pinhead quick release.
    And I know I’ll have to measure the specific size. (Diameter and length).
    Current parts:
    Front Hub:Track, bolt-on with track axle nuts, 32 hole
    Rear Hub: Track, bolt-on with track axle nuts, 32 hole
    What tool (s) will I need to do this.
    Thank you,
    Here is a photo.
  • #985527
    Pilot Pete
    Good luck with that but I
    Good luck with that but I suspect you will find the grand total of zero people who will have done that with exactly the same bike and hubs you have.
    You asked what tools you need in your first post, the video shows them.
    You are now asking if someone has already done it because you can’t take the measurements yourself because you are not privileged enough to have ‘all these tools”.
    So I am confused. If you are asking what tools you need,  the answer is there in the video.
    If you simply want the measurements, why not just buy a cheap vernier caliper? You could have got one of these ordered and delivered by now and have your measurements. https://www.screwfix.com/p/magnusson-vernier-callipers-6-150mm-/4269V?tc=FC3&ds_kid=92700066323751329&ds_rl=1244066&gclid=CjwKCAjw2vOLBhBPEiwAjEeK9umAMUM5nzz_IA1ZKJqosHK3NHbuub2_b1hVse0Uy0LGc9kWBUYuwhoCHl0QAvD_BwE&gclsrc=aw.ds
    #985525
    Theo32
    Hello Pilot Pete,
    Hello Pilot Pete,
    Yes, I did, and this was the first video that came up first for me too. Thank you.. Some people aka, me, are not privileged enough to have all these tools. So, therefore, I gave specific details of the model, type, and dimensions of my bike in hope someone has the same bike and have done the measurements already. Thank for you I’m out still.
    #985523
    Pilot Pete
    Did you not think of Google?
    Did you not think of Google? This is the first result from a search.
