Component life span on a turbo
  • This topic has 7 replies, 7 voices, and was last updated 6 years ago by a4th.
  • #31072
    a4th
    I was wondering what people’s experiences of component life spans were when used on a turbo trainer?
    I’ve got a pretty basic frame which I built up with 105 components for using on a Kickr Core. I’ve probably done 2,000km over the course of the last year and a bit and I don’t think anything needs replacing yet, but I’m conscious that I’ve got no idea about the stresses and strains of using a turbo trainer vs the real world. Anyone got any views or able to point me in the direction of some advice?
  • #969361
    a4th
    Thanks all for the comments,
    Thanks all for the comments, really appreciated. Will definitely try and do better at dealing with the sweat.
    As it turns out the thing which has ended up failing first is the frame. Probably my own fault for buying something from Planet X.
    #969359
    mtbtomo
    As per SimonAY, I would be
    As per SimonAY, I would be more concerned with corrosion from sweat. The bike I have on the turbo has paint flaking off all over, lacquered brake levers are flaking, bare steel parts are rusting…. It’s been on there for 6 years constantly and I didn’t keep on top of wiping it down when I started. The paint flaking started and now…. Well, I can flake paint off with my fingers.
    Sweat catcher and a towel I reckon for anything you want to keep in a rideable condition.
    #969357
    ChrisB200SX
    The steel levers in the shift
    The steel levers in the shift mechanisms of my Shimano 105 (5800) shifters are extremely corroded due to sweat. I make sure I wipe them off after each session since I noticed.
    If you clean and lubricate your drivetrain as you should I’d say sweat in the shifters might be the more serious issue.
    You may get no road grime in the lube but I’d suggest that it’s actually metal swarf from the drivetrain that does most of the wearing-down of surfaces. It becomes a very effective grinding paste. I believe a trainer will also probably generate about twice as many chain link articulations per hour due to fairly constant pedalling.
    I’ve switched to waxed chains now and change every 300miles, ish. Even then the wax is a bit “blackened” even though it’s only been used indoors. My SPD-SL pedal spindles are rather rusty and I’m fairly sure sweat ingress prematurely annihilated the non-driveside pressfit BB bearing (there were no remnants of bearing balls and one of the races snapped in two places, big/deep grooves in the surfaces and a lot of red/brown gunk), driveside bearing is fine.
    Chain cleaning, lubing, checking and replacement will keep things in line. You’re likely to notice when cogs are worn, having a spare 105 cassette (and chain) ready may save you trainer down time. 105 parts aren’t too expensive I’d say, probably not much to worry about right now but sensible to plan for replacement before too long.
    #969355
    SimonAY
    While you don’t get any road
    While you don’t get any road gunk on components, one thing I have noticed is that sweat is more likely to end up on your chain/front derailleur and can cause things to decay more quickly. A good sweat catcher is a must imo
    #969353
    jacknorell
    Chains don’t last as long for
    Chains don’t last as long for me though clean and lube frequently. Gone in about 2k km rather than 3-3500 km. Pedalling the entire time doing workouts so higher than normal wattage (still not much…)
    #969351
    On the other hand, though,
    On the other hand, though, you’re not collecting grinding paste from the road all over it while it’s on the turbo, so as long as you’re putting it on clean that should extend the life (in kms).
    #969349
    gonedownhill
    Consensus seems to be that
    Consensus seems to be that when on the turbo you’re always pedalling, thus an hour’s ride on there is harder than an hour outside where you’d maybe freewheel/soft pedal downhill for a certain amount of it.
    I guess by the same token if you are measuring drivetrain wear by kms ridden then you’d expect turbo use to incur wear in fewer kms than road use as you’d always be pedalling pretty hard.
    Not seen anything to quantify wear rates though.
