- This topic has 3 replies, 3 voices, and was last updated 2 years, 1 month ago by .
You’re meant to use end stops or ferrules on cables to reinforce the casing at the point of power, where the cabling meets the component. I often find that a brake cable with the slenderest of metal ferrules on it is too fat to fit into the cup provided by many brake levers and some brake callipers.
Am I doing it wrong?
I’ve just had a Fibrax brake cable fitting into one of these non-aero levers decide to go off at an angle and the inner tearing its way through the casing. It was quite generously cut so the cable hits the lever nearly at the vertical. The other side, which hasn’t (so far) had a problem, is at more of an angle.
https://www.spacycles.co.uk/m7b0s103p2728/DIACOMPE-Gran-Compe-202-Brake-Levers
