- This topic has 0 replies, 1 voice, and was last updated 6 years, 5 months ago by .
Hi,
I have a Topeak Road Morph G pump which I’ve been lugging around for the last year – finally came to use it and found the end cap had dropped off…This is the screw which holds the rubber presta/schrader valve adapter in.Just wondering if anyone knows what this screw cap is called? I’ve looked at replacement parts – but it’s looking at not much more to replace the whole pump once you factor in postage. Anyway, I’m guessing this is a fairly generic screw part, so just wondering if I can buy a new one somewhere.
The full replacement set can be seen here, it is just the screw cap I need however:
https://www.checkfrank.co.uk/topeak-rep-set-morph/1079916?utm_source=google&utm_medium=shopping&utm_campaign=adwords&dfw_tracker=34346-1079916&gclid=Cj0KCQjww_f2BRC-ARIsAP3zarHFVYsemWitrQryNd-GGK9c0cZHJi5pJz-bnDz0huo9VKDkBlP5xIgaAj66EALw_wcB
