Bib Shorts
  • #32208
    rick78
    Is their a correct way to put on bib shorts so you don’t damage them?
  • #995517
    TheBillder
    Ah, then I’d add to the above
    Ah, then I’d add to the above:
    Wash at 30 deg or less with non-bio on delicate programme. If riding short distances frequently (eg commuting) you may not need to wash every time, but your ick tolerance may vary. A surprising amount of wear can happen in the washing machine.
    Some people put socks on first so that any jaggy toenails don’t hit the lycra, and athlete’s foot doesn’t transfer to the pad.
    #995515
    rick78
    Just have new shorts and want
    Just have new shorts and want to make sure they are treated well so I can get as much mileage out of them as possible.
    #995513
    My principle works for
    My principle works for washing machines and dishwashers – if an item can’t stand the treatment it deserves to die. Closing zips does the trick – avoids half open zips tearing teeth and reduces rough bits in the wash. But a good tip, is anything delicate – or conversely anything rough (looking at you velcro) can be isolated in or out of a bag.
    #995511
    I thought hand washing is
    I thought hand washing is best but you can put the item in a mesh wash bag to avoid that damage.
    #995509
    Secret_squirrel
    Rick78 wrote:
    Dont try to put them on head first would be my advice.
    #995507
    Aside from the gripper top
    Aside from the gripper top tip, put them on as if they were shorts, then worry about the straps. If you are struggling with the straps, I’m afraid that most seem to be made for people with no body length so it can feel a bit of a stretch to climb into the shoulder straps. Most of the damage I’ve had has been washing machine catches, it seems that the webbing is prone to catching on zips of other items.
    #995505
    bobbinogs
    It’s a good tip that one.  I
    It’s a good tip that one.  I learned it a while ago as I don’t wear tights so getting shorts over leg warmers for 3/4 of the year can be quite tricky unless you roll the leg gripper over first.
    The one area to be careful of with most bib shorts are the straps as yanking them hard to pull shorts up or into place can often leave them damaged in some way, and they can be difficult to repair (ask my wife, she’s a seamstress and gets all my wardrobe faults and modifications).
    #995503
    joe9090
    You genius
    You genius
    #995501
    I’ve been doing it wrong for
    I’ve been doing it wrong for years !
    #995499
    To minimise the need for
    To minimise the need for pulling I roll up the grippers so they don’t grab at the skin. The shorts then slide on better and once everything is in place just roll the grippers back down and position comfortably.
    #995497
    TheBillder
    What damage are you seeing?
