- This topic has 2 replies, 2 voices, and was last updated 12 years, 9 months ago by .
Ok, here’s a simple question. I just bought the PI Lobster gloves. They’re fantastic except for one thing. When shifting to a smaller gear the “glove fingers” are too thick and there’s no space between the front of the drops where the levers mount and the small shift lever. I’m usually moving both levers at the same time when I’m trying to shift. I’m assuming if I take the brake lever shim out that this will help somewhat. Am I correct on this and if so, does the shim just lift out or is it secured somehow? The ultegra techdocs weren’t very clear on this.
