Wheel rim/brake surface damage?! Wtf?!
  • #20192
    richardbassett01
    Can anybody help me identify what has caused this to my rear wheel? Similar on both sides. Only just noticed it the other night whilst cleaning.
    Is it simply damage from brake blocks? Have since taken them off and and scrubbed them. The pattern of dots just seems odd. As opposed to a long scratch.
    The dots are bits of damage to rim… as far as I can tell. Couldn’t be chemical damage could it, from a ph 7 bio cleaner?!
    Any suggestions appreciated.
    Ta
  • #762621
    richardbassett01
    Cheers all. Hopefully won’t
    Cheers all. Hopefully won’t cause too much of a problem. A service engineer reckons a mavic rim stone would help remove the blemishes
    #762619
    andybwhite
    Yup! that’s salt.
    Yup! that’s salt.
    #762617
    mike the bike
    If you look at an aluminium
    If you look at an aluminium glasshouse or window frame you will probably find similar corrosion. Although the metal doesn’t rust it certainly oxidises and this process can be accelerated by contact with chemicals such as salts.
    #762615
    allez neg
    Up, I’m +1 on road salt.
    Up, I’m +1 on road salt. Unfortunately you can’t exactly coat your braking surfaces with gt85 or fs365 can you!
    #762613
    richardbassett01
    Thanks guys. Couple of lads
    Thanks guys. Couple of lads from the club reckon its road salt/grit that has done it. Hopefully it won’t be an issue but lesson learned.
    1) Switch to winter wheelset before this happens
    2) Clean bike asap post ride!
    Cheers
    Rich
    #762611
    jason.timothy.jones
    William Black wrote:Looks
    Looks like some kind of pitting/discolouration from some sort of corrosion?
    I agree, I doubt this is from the blocks at all. I also wouldn’t think a ph7 anything would cause this, but something else may have.
    Its hard to tell from the photo, but it looks a lot like oxidisation you get in aluminium cooking pots, did it scrub clean, or has it left pitting?
    It may be from something really simple like spraying air freshener or something close to the bike, or even rolling over a road that had a little spill on it
    #762609
    William Black
