Ultegra STI Levers and SRAM Force Mechs
  • This topic has 5 replies, 3 voices, and was last updated 13 years ago by IHphoto.
  • #20153
    AWP
    Hi
    Just asking if there’s any reason why I shouldn’t use Ultegra 6700 levers with SRAM Force mechs? I know SRAM only recommend using their levers with their mechs but I can’t see any reason why Ultegra with Force mechs would be a problem.
    Anyone know any better?
  • #762067
    IHphoto
    Agreed – fronts (left levers)
    Agreed – fronts (left levers) are interchangeable, but one buys and uses them as pairs usually 😉
    #762065
    IHphoto
    #762063
    AWP
    glynr36 wrote:Different pull
    glynr36 wrote:
    Different pull rations on the rear, fronts are compatible though.
    Okay. Thanks for the info.
    #762061
    glynr36
    #762059
    IHphoto
    I think they have a different
    I think they have a different cable pull ratio – Most Sram is 1:1 vs 1:2 for Shimano , from memory. So unless you can find a ‘shiftmate’ adapter (they do ones from Campag to Shim but not sure on Sram) you’re best sticking with one make.
