- This topic has 24 replies, 20 voices, and was last updated 10 years, 5 months ago by
abfibikerfans.
October 22, 2013 at 5:35 pm #20105
Bob's Bikes
Hi hope somebody out there can answer this question.
I am buying merlin’s single malt bike with a flip flop hub/rear wheel set up, now the bike comes supplied with brakes but as it’s a fixie I feel that they may not be up to the job, would I be better off buying an sram force set and swapping them over (I use these at the moment on my racer and rate them highly)
Also I haven’t found a review of this bike on any of the sites I visit, so your views/reviews would be good.
Thanking you in advance.
abfibikerfans
It seems important to know
It seems important to know the size of the gear that you ride as a lot of fixed gear riders seem to think that it is an important fact. They seem to think that the higher the gear, the better you are. This is a load of tosh as it depends on the type of riding you do and the terrain in which you ride.
The gear size is given in inches, and is calculated by multiplying the wheel size of your bike (in inches) by the size of the gear. The rear wheel was traditionally nominated as 27 inches. If you ride with a 48 tooth chain ring with a 16 tooth rear cog, you have a gear ratio of 3. (48/16=3) 27 inch rear wheel multiplied by 3 relates to a gear of 71 inches. This seems to be a typical gear and is often the gear supplied with a new fixed gear bike.
Bob's Bikes
Enough already thanx to all
Enough already thanx to all the replies (even if some of them weren’t helpful) as fourstrings said read the question =))I bought the bike mainly for the frame and running gear out went the bulls, miche piste bars TT brake levers (bit of drilling and cable routing [still thinking about reworking the front cable into the stem then down and out to brake]) and this is what I turned it into
giff77
I would echo what four
I would echo what four strings has just said. Use current brakes. Upgrade if necessary. Law says that you must have a front brake if riding fixed. Rear being optional. Though if you plan to use the flip flop then you must keep the rear. Personally I would keep both even if you run fixed only. It just gives extra control and stops you skidding. Above all else expect to have a huge grin on your face as you and your new steed truly become one.fourstringsisplenty
This is like reading exam
This is like reading exam answers by students who haven’t read the question!I’d try the brakes it comes with, fatbeggar. If they’re not great, you could upgrade, either the blocks or the calipers, later.
Do try fixed as well, though – it’s great fun! (And if you do, I’d recommend keeping both brakes, it’s just safer. You don’t have to use them, but they’re there if you need to.)
jason.timothy.jones
I think the brake question
I think the brake question really depends on what size gear you are running, if its anything under 65 inches, you may not be traveling at a speed that would justify the spend on more expensive brakes, a decent set of blocks may do the trick.Scoob_84
Don’t go zero brakes. The
Don’t go zero brakes. The hipsters do my head in thinking its cool to have to skid to break and put themselves and more importantly others at risk with their inability to control their bikes.jellysticks
Bit late for reviews if
Bit late for reviews if you’re already buying it…!?But regarding brakes:
1) running a singlespeed freewheel – BOTH brakes are absolutely essential, and the ones which come fitted are most probably fine, assuming a good setup/tune.
2) running a fixed gear – technically (in terms of physics…) no brakes are necessary but a minimum of a front brake is a VERY good idea, and preferably both, just so you can definitely stop safely and quickly. You may go down to one/none after a while but not sure what the legality of zero brakes is…best to check.
Enjoy – one gear (or “no gears” to the non-cycling…) is fantastic*
*multi-geared bikes are also great.
shay cycles
For a freewheel you MUST have
For a freewheel you MUST have two working brakes.I’ve got discs on my commuter but my road bike is almost 30 years old with single pivot campag record brakes to match and they are fine, really – even riding in bunches with everyone else on modern dual pivots an discs. Sure the new ones are better but the old ones still do the job of grabbing the rim to stop the wheels turning – you may have to squeeze the lever a bit harder so that’s just what you do!
Flying Scot
Has no one seen Premium
Has no one seen Premium Rush?BRAKES ARE DEATH!
bashthebox
My beater SS has a tiagra
My beater SS has a tiagra front brake (good) and a miche long drop rear horrorshow (horrible, obviously). But it stops me, will lock up if I tug on it in an emergency. But it’s just so wangy.
Anyway, midrange brakes are more than good enough. Force seem a little OTT if you ask me.dreamlx10
“In anything at all,
“In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away, when a body has been stripped down to its nakedness.”FIXED gear bike, front brake only as long as you have a lockring, with a freewheel on the other side you must have a rear brake as well.
Miles253
A set of brakes is
A set of brakes is favourable, if you do get a set of Force brakes you can be sure the stopping power will be good, whereas other brakes can be a touch weak. I always used a shimano caliper for my own peace of mindantonio
I have recently been to
I have recently been to Merlin’s showroom and was struck by the Merlin Malts good looks and the almost giveaway price. I just love the clean lines of a track or fixed road bike, plus they are so versatile, but for me the bull horn bars would have to go. A cheap conversion to the versatility of drops and aero levers for me, one brake or two, it’s your choice. Riding solo I’m happy with one, out with the club, unless I’m on the front all day, a brake on the back wheel is reassuring.djb123
I’d suggest not jumping the
I’d suggest not jumping the gun. Try ’em out and see whether you’re comfortable with the performance. In my experience even the low end Tektro brakes are effective enough (though I’ve only recently moved from old and battered single pivots, so anything is an improvement). Only thing is that they lack the little centering screw, making adjustments trickier.
Bob's Bikes
I so wish I hadn’t said fixed
I so wish I hadn’t said fixed now It has a freewheel so the brakes and their efficiency is rather important so could someone out there answer that question instead of telling me that you use your legs to stop on a fixie because, 1 I already know that and 2 I won’t have a whole velodrome in which to stop. -
