Sram Cassette/Shimano freehub problem
  • #20078
    Mr Jono
    I’ve just got a new PG1070 Sram force cassette in the post. I’ve put it on my Shimano R501 wheel (which I just took an Apex cassette off), but there seems to be a bit of back & forth rotational play, maybe a mm or so. It feels as if the freehub teeth/grooves aren’t wide enough.
    I’ve never had a problem fitting Sram cassettes before, am I missing something? I know the old OG cassettes had some compatibility issues a few years back.
    The freehub was fine (only about 500 miles in it since new) with the old cassette.
    Any help IDing the problem would be great.
  • #760669
    Spangly Shiny
    I needed the 1mm spacer on a
    I needed the 1mm spacer on a Mavic Ksyrium Elite but not on a Shimano DA C24.
    #760667
    Mr Jono
    Tightened the lockring – no
    Tightened the lockring – no play. Seems silly now!
    #760665
    Mr Jono
    therevokid wrote:hhmmmm…
    therevokid wrote:
    hhmmmm… never had to use the 1mm spacer on my SRAM cassettes.
    Thought that was only for Shimano 10 speed on to 8/9/10 freehubs ????
    I have a pg1070 on a R501 and with the lock ring off that too “rotates” very
    slightly on the splines ….
    That’s interesting to hear. I didn’t put the lockring on as I thought something was wrong. I’ll give that a go tonight and see if there’s still any play.
    Thanks
    #760663
    pauldmorgan
    I have Sram cassettes on most
    I have Sram cassettes on most of my bikes / wheels – no spacer in-between the big cog and the hub (unlike with Shimano cassettes).
    My son has a Shimano cassette – this does have a spacer. He once installed it with the spacer between the locking and the cassette, not a mistake he’ll make again…
    #760661
    pauldmorgan
    #760659
    therevokid
    #760657
    Mr Jono
    Is this the part i
    Is this the part i need?
    http://www.wiggle.co.uk/shimano-cs-hg-1mm-sprocket-spacer/
    #760655
    Mr Jono
    Thanks Colin. Is that sold
    Thanks Colin. Is that sold separately or should it have come with the cassette? There was nothing else in the box
    #760653
    Colin Lynch
    You’re missing a spacer that
    You’re missing a spacer that goes between the biggest sprocket and the spokes (it goes on first, before the cassette).
    It’s a 1mm spacer that you need when installing SRAM cassettes on some Shimano wheels. If it’s not included, any bike shop should have one.
