Spoke keys
  • This topic has 4 replies, 4 voices, and was last updated 13 years ago by Yorkshie Whippet.
  • #20001
    Yorkshie Whippet
    After quite a while of abuse I’ve decide my spoke key needs replacing but have hit on a problem.
    It’s quite an old round jobby with the guage on eg 15-11. As most of my spokes are ether 14 or 15 guage i decided to look for something simpler. Now the only ones I can find are metric, eg 3mm.
    Which metric size do I need or what is the conversion process?
    Many thanks.
  • #758829
    Yorkshie Whippet
    Cheers.
    Cheers.
    #758827
    chokofingrz
    FWIW, those Spokey
    FWIW, those Spokey one-size-doesn’t-fit-all ones are meant to be superior to the ring-shaped multi-size ones.
    #758825
    drfabulous0
    Sheldon Brown says
    “The
    Sheldon Brown says
    “The diameter of spokes is sometimes expressed in terms of wire gauges. There are several different national systems of gauge sizes, and this has been a great cause of confusion. A particular problem is that French gauge numbers get smaller for thinner wires, while the U.S./British gauge numbers get larger for thinner wires. The crossover point is right in the popular range of sizes used for bicycle spokes:
    U.S./British 14 gauge is the same as French 13 gauge
    U.S./British 13 gauge is the same as French 15 gauge
    Newer I.S.O. practice is to ignore gauge numbers, and refer to spokes by their diameter in millimeters:
    U.S./British 13 gauge is 2.3 mm
    U.S./British 14 gauge is 2.0 mm
    U.S./British 15 gauge is 1.8 mm
    U.S./British 16 gauge is 1.6 mm”
    Personally I would just go to the bike shop and see what fits good.
    #758823
    Marauder
    I needed to use one of my
    I needed to use one of my mates a few months ago and it was in the shape of a cross with a different size on each end, 1-4mm IIRC.
    Not sure where he got it from though.
