World Championship Road Race
  • This topic has 90 replies, 28 voices, and was last updated 13 years ago by MarcMyWords.
  • #19961
    Stumps
    I know its not till Sunday but i might as wll get the ball rolling.
    Described as a medium mountain stage its seems to fit the bill perfectly for Sagan however when you look at each lap of the course the first climb is about 4.5kms with a max gradient of 9% followed by a downhill section.
    The sting in the tail is the little burst just 6kms before the end which is only 600 metres but rises to 16% then its downhill the whole way bar a 100m lump 2.5k from the end.
    If someone gets away on the last 600m rise then its going to be hard bringing them back again.
Viewing 15 replies - 61 through 75 (of 90 total)
  • #758195
    dave atkinson
    Gkam84 wrote:You don’t get
    Gkam84 wrote:
    You don’t get badges for TTT’s…..Or so I thought??
    no badges for TTTs, ‘s in the rules :B
    #758193
    Gkam84
    Ok, I should have sorted out
    Ok, I should have sorted out Voeckler’s value.
    Anyone else I should be aware of?
    #758191
    drheaton
    I got badges for the TTT, you
    I got badges for the TTT, you don’t get the podium badge or full house badge but Stage Podium (your stage score puts you in the top three for the stage) and overall badges like High Roller are awarded and I won both.
    The balances issue will be a direct result of changing a riders cost. If Voeckler was in your team and you were on budget (full team cost of 150) then if he goes up 0.8 credits your total team cost would have been 150.8 and that’ll throw the game out.
    Either way, at least its still doing the 150 credit check.
    #758189
    Gkam84
    As for the value’s, I have no idea why its showing dodgy balances ~X(
    #758187
    ChefSpijker
    Never mind, I see the
    Never mind, I see the starting balance is 150,8 mil. so you have to leace 0,8 mil. in your balance if you want to save it…
    #758185
    ChefSpijker
    Hmmm my team profile says I
    Hmmm my team profile says I have 0,4 million left, but I can’t save my team cause it says I have spent to much budget… weird :B
    #758183
    drheaton
    Gkam84 wrote:What ITT
    Gkam84 wrote:
    What ITT badges?
    I can’t see any you would be due.
    134= backflipbedlem backflipbedlem 173
    134= backflipbedlem (Purist) backflipbedlem 173
    No full house, no podium, no last man home….. 😕 :?
    He means the TTT. Because there were 35 joint winners the game had a fit and only awarded stage podium badges to the first three teams listed and high roller badges to the first ten listed rather than awarding both badges to anyone who had a stage position of 3 and below or 10 and below.
    I assume its not just the TTT and for any stage where there have been more than three winners the same will have happened. I guess its a problem with the way the game is judging who finished in the top 3/10 (basing it on position in the list rather than listed position) and will need some coding to fix.
    #758181
    TERatcliffe26
    Rather annoyed the values
    Rather annoyed the values changed tbh, as it meant I either couldn’t change my team, or couldn’t have the team I would have had based on what the values were as even though I had + credit my team was over budget
    #758179
    Gkam84
    What ITT badges?
    I can’t see
    What ITT badges?
    No full house, no podium, no last man home….. 😕 😕
    #758177
    backflipbedlem
    You guys sorted the ITT
    You guys sorted the ITT badges?
    #758175
    Gkam84
    Its changed the values
    Its changed the values because I had to shuffle riders around because I couldn’t change the teams, you will notice that Tommy is under a UCI vest and not his normal Europcar.
    Enrique, here is the start list
    http://www.uci.ch/Modules/BUILTIN/getObject.asp?MenuId=MTY5MjQ&ObjTypeCode=FILE&type=FILE&id=ODk1MDQ&LangId=1
    #758173
    Gmancervelo
    Gkam84 wrote:Dr, check your
    Gkam84 wrote:
    Dr, check your email, I’ve done the startlist for you ~X( ~X( ~X( ~X( ~X( ~X(
    any reason why this would change rider values? voechler has gone up 0.8 and sent my team over budget, 150.5 but with a balance of +0.3. everyone else seems the same.
    #758171
    enrique
    Gkam84 wrote:… I’ve done
    Gkam84 wrote:
    … I’ve done the startlist for you…
    So the game start list ad the race start list are now both up to date?
    I can only see the following start list at the UCI site:
    http://www.uci.ch/Modules/BUILTIN/getObject.asp?MenuId=MTYzNDI&ObjTypeCode=FILE&type=FILE&id=ODkyNDY&LangId=1
    Are you guys using that one or another one?
    #758169
    drheaton
    I bet that was fun, took me
    I bet that was fun, took me an hour and a half the first time I did the road race, it was the damn Moroccans and all, their random riders that did it.
    #758167
    Gkam84
