Front crank question?
  • #19572
    cidermart
    Just a quick Saturday morning question is a 105 10 speed triple compatible as a replacement to a 9 speed Sora triple as a straight swap? I know there is a gauge difference on the chain/rollers but would it work without too much messing, as in swapping the rings over, or are they a different PCD/BCD or hole pattern?
  • #751389
    cidermart
    Apparently they do work and
    Apparently they do work and the hole pattern is the same for changing the rings over. Money spent.
