- This topic has 17 replies, 12 voices, and was last updated 13 years, 4 months ago by
Steakie75.
July 2, 2013 at 11:50 am #19269
Steakie75
Hi, Im new to this road biking thing… I recently bought a 2003 Trek 1200 from a family member as a starter bike. The frame is a little large for me as its a 56cm one and im only 5ft 6 so stretching a little and killing me when cycling distances. Im not sure whether its worth buying a new bike or just getting hold of a smaller frame. The Trek has the following set up:
Group Set: Shimano Tiagra –
Brakes: Flight deck Shifters
Wheels: Front – Mavic Cosmic Elite
Back – Mavic CXP30
Headset: FSAI know when im looking the Tiagra set is on the bikes that are £700 plus…..
Is is worth just getting hold of a smaller frame and moving the stuff across??
Cheers Guys any help is appreciated.
Steakie75
Thanks for everything on
Thanks for everything on this…gonna put the trek on ebay…..looking at the specialized Allez or maybe the secteur triple as its on at a decent price……need to go try them out but under 600 and worth a go..Not thought about the ride to work scheme, thanks for that as I may even look at increasing the budget now..
Cheers for the advise regarding frame/wheels/gearing it looks like sound advise and I will use it when choosing a new bike.
Only got the Trek as family member was selling it cheap and thought it was a good way to get into cycling…never even gave the size a thought until started riding it…. 🙂 not as easy as I thought….! :/
nickobec
A little large is an
A little large is an understatement I am 6 foot tall and ride a 56cm frame. A very short stem may make it rideable for you (but not a good fit) Get a smaller frame/bikeGroupset evolution New Sora = 3 year Tiagra = 6 year 105 = 9 year old Ultegra
So changing to Sora is not a downgrade, it is an upgrade.
Joselito
+1 with Simon E.
Sell the 56″
+1 with Simon E.
Sell the 56″ bike, I’m your size-ish and 56″ is too big.If you want start getting out riding regularly and soon, I would recommend you buy new.
You can, as other poster says trawl ebay and any local LBSS for second hand but I didn’t have much luck finding smaller frames so after several months ended up buying new (on cycle to work scheme – NB you don’t even have to cycle to work on it).
Either way you def should get yourself down your LBS and ask their advice over sizing.
Def get your legs over a few bikes –
for instance, I really wanted a Boardman but found their small a wee bit too big.
I ended up on a 48″ Cannondale which I didn’t expect to go so small but it fits and that’s the most important thing.
As said previously you can change things like position of seat, stem length but pointless if frame doesn’t fit.You may even find someone on here that’ll take the Trek off your hands.
56cm frame at 5’6″? That’s 2
56cm frame at 5’6″? That’s 2 or 3 sizes too big.I’d sell the old bike – 10 y/o components will be tired now and it’s never going to fit you – and go for a new or recent model. A Giant Defy in size Small (46cm) would be my recommendation but there’s lots of choice, the price will depend on the drivetrain level you want.
Could you use the C2W scheme with your employer? You get tax relief and pay in instalments. Otherwise browse ebay and sort by distance or check local club websites, they often have classified sections.
Tiagra (4600 series) is now 10 speed, Sora 3400 is 9 speed. The new Sora shifters are effectively rebadged 9 speed Tiagra, not at all like the clunkier 8 speed stuff. Some people like the thumbshifters on the 8 speed systems but many find it awkward.
Hector Ch
To the OP: How much is “a
To the OP: How much is “a little too big” ?I’ve read some articles on bike fit, the consensus is that you can adapt a bike that is too small for you (within reason) by changing the seat post, stem, crank length etc, but this brings into question toe overlap on the front wheel when turning.
However, there is nothing you can do if a bicycle frame is genuinely too big for you (even after you’ve changed the stem, moved the saddle forward etc).
If I were you, I would flog the Trek and get something that fits you perfect, otherwise you risk to become de-motivated if cycling causes you discomfort / pain.
Frame Swap: Unless you can do a transfer from one bike to another yourself (can require special tools, which aren’t cheap) I would recommend you take it to an LBS (If you know what you’re doing, it takes between 2 and 3 hours in my experience)
As mentioned above, you can pick up some decent used bargains, I recently bought a used BMC SL01 from 2005 with full Ultegra 6600 triple.. Cost? £400. A small overhaul (new bar tape, cables, brake pads and new tyres) was needed, but it’s my favourite bike to ride right now.
For example: http://www.ebay.co.uk/itm/specialized-allez-sport-road-bike-/151069440006?pt=UK_Bikes_GL&hash=item232c70b806
Cheers,
HectorBedfordshire Clanger
Have you tried changing the
Have you tried changing the stem (the bit that connects the bars to the steerer)?
If you buy a shorter stem then you won’t be stretching so much. You should be able to pick something up for about £25 and it will only need an allen key to remove the old one and fit the new one.
This way you’ll be able to see if you can make your bike comfortable enough to ride for a minimal outlay.If you do buy a new frame to swap all your parts onto bear in mind that you’ll probably need a new bottom bracket and you will need a new set of cables and bar tape. You also need to budget for £100 or so for your LBS to put all the bits together on the new frame or you’ll need to spend the same money on tools and a manual to do the job yourself.
juanerasmoe
I have a Giant defy 3 2013
I have a Giant defy 3 2013 with full sora 2013. It have paddle shifters and a 2×9 transmission. I love the bike and I haven’t have any shifting problems. However, this is my first road bike, so I can’t compare it with anything else…
For what I’ve read online, the 2013 sora is basically the same 2012 tiagra. The only difference between 2013 sora and tiagra is that it is a 2×9 transmission, while the tiagra is 2×10. The questions is then, how much are you willing to pay for an additional cog?StuayEd
Raleigh wrote:StuayEd
Raleigh wrote:StuayEd wrote:Super Domestique wrote:IME the downside of sora and 2300 is the small ‘thumb’ shifter as you struggle to get to it (if at all) from the drops. It’s something that doesn’t bother you when you start out but gets annoying as you progress.Absolutely, that’s one of the main things that puts it in a totally seperate “value” group from the rest of the range
Erm.
You guys are a bit behind.
The new sora has ‘tiagra style’ brifters… that is to say; no small thumb lever.
DOH! Missed that one!
I guess if there is a new Sora group I haven’t seen then I can’t comment on its quality, but I’d certainly expect the leap in quality between Sora and Tiagra remains.
Can anyone offer a more educated insight?
Super Domestique
I forgot that but still
I forgot that but still feel it’s worth mentioning in case it’s a ‘last years model’ type thing which could appeal.Raleigh
StuayEd wrote:Super
Erm.
billyman
I bought my cannondale from
I bought my cannondale from eBay with combination of ultegra and 105 for 800 quid, there are bargains aplenty if you are patient enough.ask yourself, what type of riding do you plan on doing in the future?
commute to work, just buy something cheap.
commuting and Sunday sportives, look for tiagra min
sportives and a bit of racing, look for 105 min.
also I asked the question a while back from experienced people ” what’s the most important thing when buying a bike”
I was told 1/ frame 2/ wheels 3/ groupset.
I followed that advice and I’m pleased I did.
StuayEd
Super Domestique
IME the downside of sora and 2300 is the small ‘thumb’ shifter as you struggle to get to it (if at all) from the drops. It’s something that doesn’t bother you when you start out but gets annoying as you progress.StuayEd
For example take a look at
For example take a look at this! It’s worth trawling through eBay patiently! I got an aluminium pinarello in mint condition with full Tiagra for £360 a couple of years ago!http://www.ebay.co.uk/itm/Ribble-Carbon-Road-Bike-58-Large-/251296048795
StuayEd
Personally I’d avoid Sora at
Personally I’d avoid Sora at all costs – very low end. And I’m not being a bike snob at all – I’d say that there is a clear gap between Sora and Tiagra that’s worth the price difference, whereas for a beginner, the differences between contemporaneous Tiagra and 105 ranges are negligible.For £500 you should easily be able to get a pretty decent 2nd hand road bike with full Tiagra or 105.
