- This topic has 15 replies, 5 voices, and was last updated 13 years, 5 months ago by .
Before getting the trike, the closed I’d ever come to using hydraulic disc brakes was working on friends motorbikes.
I’m having HUGE problems, it started not long after a lengthy ride. I was just pulling into the house and noticed that I didn’t have much in the way of brakes. This is going back weeks. So I tried to bleed and re-fill them. That worked for a couple of days, but soon became spongy again.
Then I tried new pads and rotors. Still nothing.
So over the last couple of days. I’ve had them off the bike, cleaned through with fluid and flushed out, then refilled and bled them. Fitted them to the bike. I got two good hard stops and now I have NOTHING, the brakes just won’t engage.
So this afternoon I bled and filled them again. I have about half power in the left side and NOTHING in the right. I just can’t figure out what to try next??
I’ve made sure all bolts on the brakes and callipers are tight, nothing is leaking and there doesn’t seem to be any air getting into the system. Just can’t work out when they are not working.
Any ideas?
