Storing Bikes
  • #18992
    nemysys
    I’m looking to make some room in the shed for a new bike..
    Space is a problem.
    What is the considered opinion of ‘hanging’ a bike by the front wheel…
    Big hook in roof spar and hook bike up…!
    Does this not put a lot of strain in the front forks…?
    Any experience out there…?
  • #740255
    hood
    #740253
    Gkam84
    If you are going to hang a
    If you are going to hang a bike by the wheel. The rear is preferable. Because the way the drop outs (unless its a track bike) are shaped, it gives you extra protection 😉
    #740251
    60kg lean keen climbing machine
    Whats wrong with hanging it
    Whats wrong with hanging it by the back wheel? (Alu frame) This is what I do with my road bike with Carbon forks, My hybrid has steel forks so I still hang it by the front wheel. I put soft cloth on the hook first so as avoid marking the rims – jobs a good un!
    #740249
    dave atkinson
    you can get a hook that hangs
    you can get a hook that hangs the bike by the pedal, which doesn’t put any strain on the frame or fork. you need a wall though, so maybe not an option for a shed. to be honest if the fork can’t cope with the weight of the rest of the bike you’d better not load it up with your body mass 😕
