Cassette help please!
  • #18826
    climbingkev
    Hi all, I’m new around here so hello – and go easy on me!
    I’ve got some events lined up for when summer arrives, namely the Dartmoor Classic and Etape du Tour and hills are not my forte (strange choice of events given my weaknesses, but they’re the ones we’re meant to target right!?). I have a compact chainset and 11-28 cassette. My question is how bigger cassette (sprocket) can I squeeze in on my 105 (5700 short cage) rear mech? Was wondering specifically if a 11-32 would fit and whether the real world gains would be significant?
    Any help appreciated,
    Kev
Viewing 15 replies - 31 through 45 (of 60 total)
  • #736271
    CanAmSteve
    The reason compact chainsets
    The reason compact chainsets and narrow clusters are in fashion is because “that’s what the pros ride” – which is about as sensible as running 23mm tyres for the same fashion-following reason (and equally useful).
    These forums have a few “The Rules”-following weight weenies who slavishly follow fashion and denigrate recreational cycling (which just happens to be way more popular with way more people – but they are out riding and not writing).
    Triples work fine, MTB gears work fine, too. You might even prefer (gasp!) a flat bar and not a racer drop bar. Maybe some people live in East Anglia and have to look up “hill” on Wikipedia, but there are plenty of steep climbs in the UK – often just pushed straight up a hill and over with no switchbacks as you find in real mountains – making them tougher climbs.
    If you think a wider range will help, by all means give it a go. Shimano Tiagra, 105 and Ultegra can all handle 30 tooth rear cogs (with the correct RD) and usually 32 will work. If you intend to swap wheel/cluster combos keep in mind chain length – you may need another chain (use QuickLinks) to match.
    #736269
    servicemycycle
    Hi
    I run a SRAM RIVAL set up,
    Hi
    I run a SRAM RIVAL set up, On the front I have 50/34 and normaly a 11-23 Cassette fitted for cummuting and general use!
    I also own a 11-32 and Medium cage mech on the cheshire cat 2015 and the cheshire cobbled classics 2014 the 11-32 will go on as they both involve a lot of climbing when I did the C2C in june I didnt have 11-32 on the 2nd day with near 2000m of climbing the extra teeth would have been so welcome
    the rest of the time the 11-23 will stay on to keep a certain level of strength in my legs the more you ride and the harder you push the fitter you will get but you still have to enjoy it!
    if its going to be a hilly ride its only a 10 minute job swaping over and I dont care when people say about my choice of gears I generally get up the hills quicker on my 34, 23 than they do I just choose to make it easy!
    #736267
    truffy
    DaveE128 wrote:If you believe
    DaveE128 wrote:
    If you believe riding fast up steep hills is essential to avoid falling over
    No, but if you go slow enough you do fall over. Trust me on this! 🙂
    #736265
    Shades
    I just wrote this in another
    I just wrote this in another ‘thread’ but seems just as applicable here….
    I investigated the whole compact/triple ‘business’ when I bought a road bike and boy were there some megabytes of data on it. Opted for a compact in the end but where I live is pretty hilly so I’m occasionally out of the saddle. I was recently in the Vosges and Swiss Alps and triples were EVERYWHERE! Granted it’s a bit more ‘hilly’ but they were being ridden by ‘wiry’ locals who looked like they spent most of their spare time riding bikes. I remember a Dutch couple burning past me on a Cat 1 climb; I was in my lowest gear and they still had a few more to play with. I went into a local bike shop and was admiring a row of Orbea bikes (incl carbon); all fitted with triples and not a compact in sight. A friend of mine who has done the Etape and Marmotte said that he’d wished he’d had a triple on the final climbs. Not sure it matters what you’re riding but nothing beats overtaking someone on a hill riding a more expensive bike than yours.
    #736263
    Hensteeth
    My first road bike (felt f95)
    My first road bike (felt f95) came with compact 34/50 and a 11/25 cassette. After struggling up hills a bit I changed the cassette to a cheap 11/32 Shimano one from wiggle (about £9) fitted it with a new chain and it works fine on the 9 speed Sora derailleur. I think it is a medium cage. I was advised by several people that it wouldn’t work but it is absolutely fine. Didn’t even need to tune the gears! Needed a slightly longer chain.
    Just got a new carbon bike with Sram rival 12/28 and it feels about the same on the hills as the 32 on the heavier bike. But been out in the wind so not properly road tested it yet. Definitely faster tho. 😉
    Like others have said it is definitely better to apin up the hills than grind away. Your knees will thank you and you will enjoy it more and therefore ride more. Which is what it is all about. When was the last time you checked out the other guys cassette?
    #736261
    DaveE128
    Why some people think it’s
    Why some people think it’s not the done thing to cycle at an efficient cadence up long steep hills, I cannot understand.
    Personally I say put on whatever gears you need to maintain a comfortable cadence up the steepest hill you have to deal with.
    If you believe riding fast up steep hills is essential to avoid falling over, I think that’s a different problem and it might be wise to work on your bike handling. With practice it is perfectly possible to ride an 26″ mtb or tourer with a 22×32 gear up very steep hills at an efficient cadence without wobbling that much.
    #736259
    enrique
    seoul wrote:My wife and I
    seoul wrote:
    My wife and I retired to Korea…
    Damn fine post…
    #736257
    seoul
    My wife and I retired to Korea and I shipped out my 20-speed Felt F75, a good entry-level road bike. Whereas the 11-28 cassette was fine for me in London, I was struggling on Korean hills even in the city. To give you an idea of the gradients, the first time I unloaded a toolbox from the car outside our flat I made the mistake of putting it on the road. It accelerated downhill until it lodged against a tyre of the next car down. Plenty of hills like this.
    So, with the Felt 8 years old and needing replacement chainrings, cassette and chain, I switched to a 12-32 and my original Shimano 105 copes fine. I can vouch that the extra 4 teeth do make a difference; I can now cycle up to my gate and climb pretty well all the local hills.
    Losing weight, getting fitter and putting up with pain? If your cycling is more endurance than enjoyment, you’ll probably give up long before your free bus pass and pension. After 50 years on more bikes than I care to count, I’m routinely getting up at 5a.m. this summer to enjoy riding before the temperature hits 30C. We also have a self-built timber house on a steep mountain road in the countryside. For this I ride my Giant XTC with 30 gears. You’ll read comments about modern bikes having “too many gears”. Well, I wouldn’t like fewer: they all get used within the first 10 minutes of steeply undulating mountain roads.
    Finally, when you get to the wrong side of 60, your legs don’t rev like they used to. You become more diesel, less petrol, you have the torque but the legs can’t be persuaded to fly round. More gears over a wide range mean that the legs can keep a steady rhythm and frequent gear shifting takes care of the road speed.
    Enjoy riding and you’ll cycle more and drive less. That’ll go a long way towards fitness and weight control. When retirement gives you more time for cycling, you’ll be keeping up with the speed merchants half your age and it won’t hurt. Honest!
    #736255
    FMOAB
    If you want lower gears go
    If you want lower gears go for it. I recall seeing an article here last year that showed Wiggins Tour bike with a massive cassette on the back and a rear mech put together by the mechanics using an mtb cage to give it the capacity required. Me, I recently installed a deore xt mech so that I could run a 32 on the back – and I’m on a triple.
    Just remember to be courteous to the purists pushing their bikes up that 20% as you pass them in the saddle 🙂
    #736253
    chiv30
    dreamlx10 wrote:chiv30
    dreamlx10 wrote:
    chiv30 wrote:
    dreamlx10 wrote:
    Still no need for your use of the word “Prick”.You obviously can’t handle criticism, even though it’s not directed at you.
    Anyone else notice the irony here…..
    :evil:
    I don’t think calling someone a “Prick” is criticism though. It’s just name calling.
    I think I called you an elitist prick, this was based on your response thus criticism, however just a prick would have been name calling , in that respect you are correct .
    Now I have passed my helpful advice on, so I am happily finished with this thread however I do believe the op also asked for your most hated kit so by all means carry on and answer him 😀
    #736251
    Old Cranky
    I fitted a 105 5701 GS rear
    I fitted a 105 5701 GS rear mech and SRAM 12-32 Cassette to my son’s road bike. It works perfectly.
    #736247
    edster99
    chiv30 wrote:big mick
    chiv30 wrote:
    big mick wrote:
    dreamlx10 wrote:
    I would say if you can’t get up any of the hills with a 34/28 then don’t bother going you either need to lose a lot of weight or get fitter.
    So true
    It isn’t true at all , as the op said his fitness and weight aren’t an issue he just wants to make his hill climbing easier …. It’s no wonder people stick to mtbs with attitudes like this :O
    OK so to put my cards on the table : I have had a bike with a triple up until recently. I’ve got a compact now – 34 / 25 min gear. The lower the gear, the faster you need to spin to go fast enough to not fall off sideways. A bit more strength allows you to push a slightly bigger gear at a sensible cadence. That’s my roundabout way of saying – go for it on a really low gear, but over time if you get stronger you hopefully wont need it any more!
    And if you only use the biggest sprockets on the small ring, and the smallest sprockets on the big ring, and don’t cross over too much, you can probably get away with a short mech. That requires some ‘gear discipline’ 🙂
    #736245
    chiv30
    big mick wrote:dreamlx10
    big mick wrote:
    So true
    #736243
    big mick
    dreamlx10 wrote:I would say
    So true
    #736241
    In the end we can only make
    In the end we can only make suggestions to the OP, he can choose to buy whatever he likes. Being rude doesn’t help anyone.
    Dave Atkinson wrote:
    Contador ran a 32T on the day the Vuelta went up Angliru last, and he wasn’t the only one. Millar ran an XX mech and a 36. You going to tell them to man up? Use the gears that work for you.
    And Cobo won that day (and more or less secured the Vuelta) because he twiddled up in 34×32 while Brad and Froomey honked and stalled with their 38t oval chainrings.
