The chain split!
  • #18775
    Richthornton
    So my chain split whilst out on a ride today. Had a chain splitter and missing link, so got it repaired no problem. After repairing it, the chain was 1 link shorter than it had previously been.
    I should have picked up on the warning signs, the chain had been talking to me for some time, seemingly trying to shift a gear of it’s own accord and slipped off the small chainring once as well.
    Now the funny thing is that after repairing the chain everything seemed better. Gear changes were sharper and neater, much less rubbing and chatter. I didn’t alter anything else. Didn’t adjust the indexing.
    Could it be that I should have been using a shorter chain all along? I have always matched the length of the chain to the previous one when replacing it. Can a shortening of a couple of links really make such a dramatic difference or is it my imagination?
    Do I now need to buy a new chain given that it now has 2 missing links in it or is it safe to continue to use?
    Thanks to anyone who has something to say on this.
  • #734643
    Bing Bell
    Hope this link works.
    This is
    This is the method I used when I first installed a new chain yonks ago.
    I just count the links on my old chain now.
    http://techdocs.shimano.com/media/techdocs/content/cycle/SI/SI_5X90B/SI-5X90B-003-00-ENG_v1_m56577569830702204.PDF
    Have a look at centre-bottom of this Shimano pdf, there’s a diagram showing correct chain length.
    #734641
    racingcondor
    I’m yet to see a chain that’s
    I’m yet to see a chain that’s so worn that it’s an entire link longer. Old vs new is fine as long as the old one was the right no. of links.
    #734639
    Richthornton
    Harry.horler wrote:Never
    Harry.horler wrote:
    Never measure your new chain against your old chain. Your old chain is worn out and stretched. This only makes your new chain to long. If you have changed your chain a couple of times your chain is only going to get longer and longer.
    The formula for measuring your new chain is :-
    Run your new chain over and around the two biggest cogs (chain set & cassette ) but not through the rear derailier. Have the chain overlap by 3 links. This should give you the correct length. Then put the chain on properly and join it. Once the chain is on run it on the two smallest cogs, the chain should not hit the rear derailier. Also run it on the to biggest cogs to make sure it’s not to tight.
    There are lots of good YouTube videos to watch which explain it.
    Harry, owner of Glastonbury Cycles
    Thanks for the advice Harry, Although I don’t doubt your knowledge, I was under the impression that the chain doesn’t actually ‘stretch’ as such but the pins wear down causing the gaps between links to increase, but the length of the chain overall wouldn’t change.
    (http://cyclingtips.com.au/2009/03/how-to-check-for-chain-wear/)
    am I mistaken?
    However I will definitely be taking your advice for fitting the new chain as the length of the old chain will have no bearing on that method, thank you.
    Rich
    #734637
    Richthornton
    Bedfordshire Clanger
    Bedfordshire Clanger wrote:
    Rich, forgive me if you know all this already, how old was that chain? How many miles do you think it had done? Do you own a chain wear indicator and do you regularly check to see if your chain is worn out? If the chain had done a few thousand miles you will have worn out your cassette too and if you just fit a new chain it will constantly slip over the worn sprockets on your old cassette. If you don’t have a chain wear indicator already they are cheap and well worth having as you will be able to tell when to replace your chain before it totally wears out and save on new cassettes, jockey wheels and even chainsets if you replace in time.
    The chain and cassette were both replaced in mid-February and have done about 1000 miles since then so I doubt that either of them are worn. I do have a chain checker although I don’t regularly check it, I guess I didn’t consider that the chain could have been worn yet given the low-ish mileage on it.
    #734635
    #734633
    Harry.horler
    #734631
    Richthornton
    Oh I’ll definitely be getting
    Oh I’ll definitely be getting more spare links, I would’ve been stranded in he depths of Cumbria, miles away from anybody if I didn’t have one with me today!
    #734629
    crash144019
    Yep shortening a chain by one
    Yep shortening a chain by one link can make that difference. Definitely replace the chain though and get another spare link
