- This topic has 1 reply, 2 voices, and was last updated 13 years, 4 months ago by .
I have a pair of ‘old’ Mavic rims that measure about 21mm across the rim. I have a pair of 23mm tyres fitted that I want to replace with something wider for a bit more air volume when I do Nightrider.
I was thinking of going to 25mm but should I be OK if I go up to 28mm?
I have plenty of space around the forks and seat stays and there is ample clearance inside the brakes which are Campagnolo Mirage.
