new mini pump
  • #18430
    okeydokey79
    ok my pump broke at the weekend and im now on the look out for a new mini pump(i have a track pump at home) dont really want go the co2 option, been looking at the topeak race rocket hp,leyzne tech drive hp also the lezyne pressure drive all around £26 the tech drive bit cheaper at £23,i know every1 has different opinions but was just after a bit of feed back on any1 who uses these on how good/bad they are.wanting 1 with the hose as when i was using my last pump i was scared of breaking the valve 🙁
  • #726793
    Leviathan
    If you want to go micro, try
    If you want to go micro, try the Airbone. It is 10cm long so you just carry it in your jersey pockets with a spare tube folded and levers. It does obviously take a bit longer to pump but it has a screw on valve so no air spills out. Whatever you get try to get a screw on as they are much more efficient than a simple clamp over and flippy switch type.
    #726791
    pirnie
    If you worry about breaking
    If you worry about breaking valves then the lezyne pumps with hoses are a good choice, much less likely to damage a valve core. I know the road drive has it, but that’s not exactly mini. Some of their others have the hose though too I think. In my experience lezyne stuff is always great quality as well, loads of neat design touches.
