Tubular for daily use – Any thoughts?
  • This topic has 21 replies, 12 voices, and was last updated 11 years ago by mellowmiles.
  • #18408
    AWP
    I’ve decided to give tubulars a go. I’m after a 25C tyre to use on a regular (nearly daily) basis. I was looking at the Schwalbe Ultremo HT but I’m concerned that the latex tube will mean I have to pump them before every use.
    Will that be the case?
    Others I’ve looked at are:
    Tufo Elite Ride 25
    Vittoria Corsa CX
    Can anyone give me any advice on a suitable option, possibly from the list above?
    Many thanks.
Viewing 15 replies - 1 through 15 (of 21 total)
  • #726109
    mellowmiles
    how did you get on with tubs
    how did you get on with tubs then??
    #726107
    arrieredupeleton
    Planet X video showing how
    Planet X video showing how quickly a tub can be replaced (admittedly edited a bit but interesting nonetheless):
    #726105
    700c
    Agreed and undetstood that
    Agreed and undetstood that the need to inflate tyres is no worse on tubs than clinchers. In fact my clinchers use latex anyway so I’m used to adding 20 more psi in the morning..
    I think there are some misconceptions about the hassle of tubs, and perhaps unfounded safety concerns about installation and repair, but you have to have confidence in your equipment otherwise you’ll never fulfil your potential.
    Tubular wheels are a big investment and there’s always some risk that you won’t get on with any different or new system. Personally I’m confident the benefits will outeigh any potential risks so my long term plan is to invest in tubs.
    Apologies that this thread had been hijacked by a tubular/ clincher debate, but it’s proved quite useful to me, so thanks all.
    #726103
    RichTheRoadie
    Oh the tape holds perfectly
    Oh the tape holds perfectly well (as long as you don’t use glue as well [I can’t believe people do that]). All I’ll say is have fun cleaning up the tyre and rim when you have to remove one – something you don’t have to do with glue, but is essential with tape.
    As I say, tape is for wrapping presents…
    #726101
    AWP
    Update:
    Tufo (butyl inner)
    Update:
    Tufo (butyl inner) tubulars have been on for a week. Have topped the pressure up once, only needed a few psi.
    Fitting with Tufo tape was so easy a 10 year old could have done it. Tyres haven’t come off the rim as yet. I spoke to a number of people, including a very switched on individual and well known wheel builder, and was told there are no issues with the Tufo product; infact it was recommended by some.
    I am not carrying a spare. I have a bottle of sealant and a valve core removal tool. If/when I get a flat I shall report back how I got on.
    As an aside, the carbon rims/brakes are excellent, however, I haven’t had to use them in wet conditions.
    #726099
    RichTheRoadie
    Welsh boy wrote:berni
    Welsh boy wrote:
    berni wrote:
    Even without any glue a well inflated tub will get you home, just try rolling one off!!
    That is the most irresponsible post i have ever seen on a cycling forum.
    And you followed it up by suggesting a method which mixes sticking methods and is no more secure?… 😕
    Seriously though, why bother carrying tape? Just pre-glue! It DRIES. It is NOT sticky. It sticks when it contacts old glue on the rim. Why bother with anything else?!
    Tape is for wrapping presents, not sticking tyres.
    #726097
    Welsh boy
    berni wrote:Even without any
    That is the most irresponsible post i have ever seen on a cycling forum. Kill yourself by all means but do not post potentially lethal advice for others to follow. A sharp, unexpected corner will easily roll a tub which is not glued on properly. I have seen glued on tubs roll so i can only assume that you dont corner very hard and have (so far) been lucky.
    Try carrying a roll of tub tape with your spare, easy to use and works well.
    #726095
    RichTheRoadie
    Having to pump the tyres up
    Having to pump the tyres up every day is just something you should always do!
    Yes, latex tubes lose more air overnight than butyl, but I still lose enough through butyl tubes (or butyl tubed tubulars) to make the bike squirm.
    Worried about carrying a spare? Don’t be: http://biketart.cc/2012/05/david-asks-the-bike-tart-or-how-i-rolled-that-spare-tub/
    This is how that looks on a bike:
    http://farm9.staticflickr.com/8525/8584521455_941b4c9ec9.jpg
    Hardly cumbersome eh?
    Lately I’ve kind of ‘accidentally’ been using the FMB Comp CX 25c tyres pictured above as daily use tyres. They’ve been incredible. Around 1000km in and not a single cut. I weigh 82kg on a good day so most tyres cut easily under me!
    I have a set of clinchers being built next week – I’m desperately trying to source a set of the tubular version of the clincher rims I was going to have because I just don’t understand why I’m building a set of wheels that carry no benefit.
    #726093
    RichTheRoadie
    Oh, and you don’t re-glue on
    Oh, and you don’t re-glue on the road – it’s contact adhesive, you [i]pre[/i]-glue!
    #726091
    700c
    Correct me if I’m wrong but
    Correct me if I’m wrong but having to pump the tyre every day is down to the latex tubes and not tubulars per se?..
    I’m interested in this thread as I’ve been debating making the move to tubulars.
    I’m worried about the hassle of carrying spares and re-gluing on the road, but it may be worth it – how else do you access the aero / ultra-lightweight wheel market?
    1 kg wheelset is very tempting!
    #726089
    Leviathan
    pashda wrote:They are great
    pashda wrote:
    They are great and providing you are happy to pump them up before every day they are no problem.
    Thanks, you have convinced me these aren’t for me. I am quite happy changing the odd tube on the road if I have to carry less, and I am certainly not pumping every day. My clinchers stay rigid for a couple of weeks at a time.
    #726087
    AWP
    I was after advise on
    I was after advise on choosing a tubular to use on a daily basis. Again, thanks to those that have replied.
    I wanted to tryout both carbon rims (38mm) and tubulars as a bit of a test really just to see how both items perform. I’m looking to fit them on my commute bike (Planet-X SL-Pro Flatbar)as they will get a good testing there.
    I have decided to fit Tufo Elite Ride 25C tubulars. People have said that the Tufo tubes are a bit harsher than others, this is mainly because they use butyl rather than latex inners. I’m happy with the harsher (harsh by tubular standards) ride on my commute as it means I won’t have to be pumping them on a daily basis. I can carry a small bottle of Tufo sealant which, according to many, will deal with most punctures. The Tufo seems to be the only 25C tubular that has a butyl inner, and I think I’ve just bought the last black/black pair in the UK! I also intend to use Tufo tape to fix them to the rims; I’ve heard good things about that product too. I’m not a Tufo sales rep – honest.
    Most tubular riders I’ve spoken to have given up carrying a spare, they are that confident of not getting flats but agree it took a while to get to that point. I believe they generally use something like Stans Sealant which works better on the latex tubes. I’m hearing conflicting info on this so I need to dig a bit deeper. Tufo only recommend using their sealant on their tubes.
    If you’re interested I let you know how thing go; I hope to have everything together next week. If I survive the carbon brakes……
    #726085
    pashda
    I use tubs on my TT bike
    I use tubs on my TT bike mainly because the bike came with them on the aero wheels. They are great and providing you are happy to pump them up before every day they are no problem. A spare takes up slightly more room than an inner tube but fits ok in a seat pouch as you dont need to take tyre levers as well. They are quicker to change than a clincher and you dont need to pre-glue the spare. The residual glue on the rim will be enough to hold the spare on until you get home. Of course you pay more for a new tub than a new inner tube which is what puts most people off
    #726083
    berni
    Changing a tub is quicker
    Changing a tub is quicker than a clincher, just pre stretch your spare. I carry a tuft lightweight (about 160g) as a spare and never needed it yet. Even without any glue a well inflated tub will get you home, just try rolling one off!!
    #726081
    Leviathan
    This thread has made me
    This thread has made me investigate tubular tires, especially as I am considering/saving-up-for some aero wheels. Most ‘fancy’ wheels now come with a clincher options so tubs is an option not a requirement.
    I was interested to learn about pinch-flats and have to say I have had them before but didn’t know what they were called. The distinctive double holes gives them away. In fact since I got my Continental GP4000S last summer (which I love and will reply to any tire thread to suggest them) I have had maybe 4 flats and they have all been this kind. I blame the gravel and stones on the road these days.
    So the idea of even less punctures with tubulars seems great. I get how they deform the full tire and do not overlap the wheel edge. However, here is the big BUT: I checked some vids on youtube about changing them and it just looks a terrible fuss compared to an inner tube. I struggle to see how they can be so much better performance as to be worth carrying one of two spare tires around in a sportive.
    Currently I go out training with a micro pump, inner tube and irons in my back pocket. I still have space for extra tubes if it was a long race, where would I put a whole tire? Would I want to fold up and carry a wet dirty punctured tire?
    Without a team I just don’t get it. Please someone tell me what I am missing?
