- This topic has 21 replies, 13 voices, and was last updated 13 years, 6 months ago by
KiwiMike.
March 30, 2013 at 3:02 pm #18364
timb27
Started using Strava and wondered if anyone knew if the stats it collects via my iPhone are reliable? Went out for a 60k ride up 7 East Devon Hills yesterday, and the app said 1200m and then corrected itself to 1015m of climbing. Then I saw a ride 2 mates did together this morning – 1 said 400m and the other said 650m!
If the elevation is off, does that mean the top speeds are as well? I was quite proud of my 50mph segment from the top of Observatory Hill down to Sidbury!
KiwiMike
Taking my last Strava GPX
Taking my last Strava GPX file and putting it into Google Earth shows that the Strava height gain is underestimating by 14%. My Suunto T6 with barometric sensor gave more like 5% error on the Google Earth figure.The total altitude gain Strava estimates is a calculation based on map database of heights for a given Lat/Lon as recorded by the phone’s GPS. Some devices with barometric sensors use these in prefeence – like the Garmon 500 et al. https://strava.zendesk.com/entries/20965883-Elevation-for-Your-Activity
StuayEd
No problem!
No problem!MattT53
Thanks, a lot. That’s a great
Thanks, a lot. That’s a great help, much appreciated!StuayEd
MattT53 wrote:Strava always
MattT53 wrote:Strava always gives a lower avg speed than the data directly from my garmin. I assumed this was due to what im going to call gps drift (i.e when stood still the garmin reads 0.5 mph or so)?
Also, does anyone know how do you go about defining a known elevation for an edge 800? (i’m a bit technolically challenged!)Matt,
Goto this website and navigate to the location that you want to predefined the elevation for. It will tell you (using your choice of NASA or OS data) exactly how high above sea level a given location is. Best to use a proper computer, rather than a phone or tablet for this website! http://www.osola.org.uk/elevations/
Once you know the elevation of your given location:
1) Goto the map screen on your Garmin and press the icon with the four arrows, to enter full screen mode.
2) Pan around and zoom out / in to find your chosen location? Once you’ve found it, zoom in to make your saved location as accurate as possible.
2) Tap at the precise place you want to define the elevation and a pin will drop in place on the display. If you mess up, just tap again and it’ll move.
3) at the top of the display you’ll see a little information box with the coordinates and elevation displayed (carry on even if the elevation is correct as you want to override the barometric sensor on the Garmin and ensure it’s always correct at the start of a ride – this only happens when you predefine).
4) Tap on the information box and you’ll get a new screen with 3 buttons along the bottom. The middle one is a little flag on an “x” a as in “x marks the spot”. Press it!
5) your Garmin will say something like “location saved as 001” a click ok.
6) A new screen will appear like before except the middle button is now a pencil – press this to enter edit mode to edit the location.
7) now you can change the name, the symbol it is displayed as on the map (think office block for work or little house for home) and crucially the correct elevation.
8) Scroll down to “change elevation” and select it.
9) Use the delete key top right to get rid of all the zeros and type in the correct elevation. You must fill all 5 spaces, so if your location is 45 metres above sea level, you should out 00045. Then press the green tick.That’s it! Now whenever you start the Edge’s timer within 50 metres of that location it will automatically set the elevation to whatever you put in and then give much more accurate readings based on the barometric pressure. It’s like automatically calibrating it every time you start a ride.
You’ll also find that you can navigate to your saved locations easily by going to the “where to” menu and selecting “locations”. Great if you’re half way round a route and decide for some reason that you just need the quickest route home possible etc and want to use your edge as a sat nav!
dave atkinson
notfastenough wrote:Dave
notfastenough wrote:Dave Atkinson wrote:the iphone 4 uses a Broadcom BCM4750IUB8 single-chip GPS receiver. so yes, it does have proper GPSnot all chipsets (and not all chips of the same type) are equally capable. I’ve had two HTC One X handsets and the GPS tracking on the first was noticeably better than on the second
I checked – you’re quite correct, although it appears to be supplemented by cellphone signal triangulation and wi-fi networks. I assume the GPS chip alone isn’t as good as others, otherwise why bother with the other stuff etc.
most phones use other networks to augment GPS data, because it can extend battery life. there’s a new system in development which takes very small snippets of GPS data (fractions of a second rather than the tens of seconds it can sometimes take to get a full fix) and computes location from that, other network data and the phone’s past locations via the cloud. the developers reckon this could hugely extend battery life when GPS is on
sm
Garmin connect has a feature
Garmin connect has a feature to enable elevation corrections, which I think are taken from proper maps. The feature is on the bottom right of each individual ride. Not that you should obsess too much, it’s only a guide and your legs will certainly tell you when you’ve climbed enough!MattT53
Also, does anyone know how do you go about defining a known elevation for an edge 800? (i’m a bit technolically challenged!)timb27
Looks like a Garmin is the
Looks like a Garmin is the way to go then, plus sensors for speed, cadence, power, altitude and heart rate. Better start saving.Anonymous
you certainly should not
you certainly should not trust your Strava segment times obtained with a Strava phone app; somehow my Strava app tells me I’m much faster than I really am, as shown by my Garmin Edge 500 with speed/cadence sensor.Not surprisingly, a lot of the KOMs in my locality are recorded using Strava phone apps…
notfastenough
dave atkinson
notfastenough
If I remember correctly, the
If I remember correctly, the iphone doesn’t actually have GPS – it triangulates it’s position based on cellphone towers*, aided by the location of local wifi networks**. I’m not sure if altitude is calculated based on the same triangulation (that sounds flaky) or a co-ordinates lookup of your location against an OS map with altitude data derived from there.Contrast all that with a Garmin, for example, which is a ‘true’ GPS device relying on satellite positioning.
Over a 100km ride, my phone and Garmin differ by maybe 1km distance, so not a big deal. I’m not sure about difference in ascent.
Overall, I think the phone app is definitely useful. If I have the battery life, I record on both, then if I’m in a rush later, upload from the phone (easier) rather than booting the laptop and hooking up the GPS, which is a bit of a faff.
* = If a phone has ‘proper’ GPS, then in theory you can still navigate when in aircraft mode (i.e. no phone or data signals), but the iphone 4 will do no such thing.
** = This may have changed for the iphone 5 when maps data switched from google to Apple.I got this phone ages ago, so I may be talking bollocks, but hopefully not!
StuayEd
HappySnidge
HappySnidge wrote:http://www.uttoxeter-news.co.uk/News/Uttoxeter-cycle-thefts-lead-to-smartphone-apps-warning-20130309110405.htm“Our investigations have shown that some of the victims had been using websites and mobile phone apps to log their routes – these sites allow users to view each others routes and track their rides.
“Some of the GPS data recorded and shared on these sites is so accurate you can pin point the house where the journey’s have begun and ended.
“We suspect some thieves have been using these sites to identify potential victims and high-value bikes.
There have been lots of stories like this in the press recently and it’s definitely a concern – it’s worthy of note that in the privacy settings on Strava, you can set up a 500m exclusion zone around your house that means followers can’t see the start or end of your ride if it enters that exclusion zone. Tat way no one can possibly identify where you live. I’d recommend that everyone should set it up!
StuayEd
Like others have said, I
Like others have said, I wouldn’t trust GPS alone for accurate speed or distance data. If you want proper accuracy, combine a Garmin with a speed / cadence sensor that uses the size of your wheel to know EXACTLY how far and fast you have travelled.As for elevation, that’s far more troublesome. Elevation calculated by GPS is very haphazard for a host of very complicated reasons. If you can afford a Garmin with a barometric pressure sensor, you can find out the correct height above sea level for places you start your rides from, such as home, office etc and pre-define them in your Garmin. The elevation readings it gives based on changes in atmospheric pressure as you climb or descend are then pretty accurate – certainly more accurate than GPS.
If you consult Strava’s help pages you’ll discover that they use data submitted from Edge 800 users over smartphones to correct their data as it is much more accurate.
To summarise, smartphone GPS not great, Garmin GPS better, Garmin GPS with speed / cadence as good as you can get, but none of this tech will be 100% accurate for elevation.
There’s a good blog from @StravaTips comparing smartphones to dedicated GPS linked below – I’ve never regretted investing in an Edge 800!
HappySnidge
