- This topic has 5 replies, 6 voices, and was last updated 13 years, 8 months ago by .
I wonder if anyone can help me.
I have a 2012 Carbon Cube GTC Pro and have had the Cube ‘fix’ by my LBS to resolve the internal cable rattle issue in the top tube. Problem is it hasn’t worked / been fitted correctly and still rattles to the point of driving me mad.
Does anyone know of a aftermarket foam type product I could slip down the cable to sort it once and for all. It would need to have an internal bore the size of a brake cable sleeve and an external bore of less than about 5-6mm to fit through the cable exit hole in the top tube.
Any help would be much appreciated.
