Urinary Incontinence; How Do I Ride Now?
  • This topic has 18 replies, 10 voices, and was last updated 8 years ago by hawkinspeter.
  • #17785
    QAEngineer624
    Hi Everyone,
    I recently had surgery that has left me with urinary incontinence. Hopefully, this will be a temporary issue.
    Does anybody have any advice for me regarding management of this issue?
    By the way, I do road cycling and typically wear lycra cycling shorts with a chamois.
    Any advice would be helpful.
    Kind Regards
  • #713683
    JamesHalford2k18 wrote:
    Did you know cycling fitness is gained depending on how you rest and recover? Find out the best method as well as other health and fitness tips by clicking the link!
    https://www.probiketool.com/us/ride-faster-and-feel-better-cycling-fitness-and-health-basics/
    Did you know that JamesHalford2k18 is spamming links? Any chance of banning him?
    #713681
    JamesHalford2k18
    #713679
    Chris Moray
    Hi everyone especially
    Hi everyone especially QAEngineer624 in Canada. I too have had incontinence problems after being diagnosed with aggressive prostate cancer over a year ago, then a radical prostatectomy, hormone and radiotherapy. This came out of the blue and for a long time cyclist (55 years) it really sucked, especially as I had just retired and had planned some mega audax events and long distant charity rides…   The problem with surgery is that it takes away two of the main means by which you control urine flow and you then have to retrain the pelvic floor muscle. Nearly twelve months later  I still struggle to the extent I didn’t want to meet people, or engage in sport, it was just too stressful. I didn’t cycle for six months and then gradually got back in to it at a pretty basic level. I started cycling with my club after eight months and usually met them half way on our usually morning rides before getting to our cafe stop. I carry at least two pads and just have to lump it if I leak and wet my bib shorts. It is embarrassing and often humiliating and  stressful, even if my mates are not aware of me peeing. The only plus thing is pressure from the saddle does slow down the leakage, stand up for a hill section and out it comes. I have started to adapt to staying on my saddle for the hills, just shifting forward a bit. After  and hour or two I do get  uncomforatble down below with my bib pad and the incontinence pad; I guess the answer there is to get some padless bibs. It s hard folks and globally one on seven men are predicted to get prostate cancer. If you are in your fifties, get up to pee in the night or get a UTI, get checked out with your GP/physician. QAEngineer, take care and hope you are getting out on two wheels regularly.
    #713677
    DoctorFish
    I started reading this with
    I started reading this with interest not realising the initial post was 5 years old.  Thank you for coming back, resurecting the post, and updating with your current progress.
    #713675
    Mungecrundle
    It is important that these
    It is important that these types of issues are talked about. Real people, real problems, good advice for others who might face similar challenges.
    Hope you have a great cycling season.
    M
    #713673
    QAEngineer624
    Update:
    Update:
    It’s now 5.5 years since surgery.
    Return to normal has been slow but not complete; there is still residual effects.
    The practice is to empty before riding, put on ther shorts and use a light or medium pad.
    I wasn’t able to ride much last year and this year I’m getting a late start due to home projects and feeling under the weather.
    Going to start slow for some short rides and them build up speed and endurance.  The speed and edurance are not effedts of surgury, just personal limitations.
    #713671
    QAEngineer624
    Update:
    Well, it’s summer and
    Update:
    Well, it’s summer and I’ve had the opportunity to ride outside. With the aid of some ‘protection’, I am able to ride without much interference from my ‘condition’.
    My ‘condition’ has significantly improved but I still need a pad whether on or off the bike.
    I’m writing to provide some encouragement to others who have the same issue as I have.
    Now, if I can only find more time to get on the bike!
    #713669
    QAEngineer624
    Many thanks, Tour Le
    Many thanks, Tour Le Tour.
    Great idea. Now I’ll have a legitimate excuse to wheelsuck and/or ride without friends.
    Honestly, thanks. I will look into it – it may be one of many techniques that I’ll have to use.
    Cheers.
    #713667
    Tour Le Tour
    As someone else said, ewww.
    As someone else said, ewww. Sounds pretty unpleasant, so you have my sympathy. Hopefully everything will be functioning again by the time you get back out on the road. On the off-chance that you are still having problems though:
    I started a long race a few years back, and kept catching a flash of light of the leg of one of the guys in the bunch. At first I thought it was just bouncing off his deep tan, and then I realised that there was something attached to his leg. It was a very small diameter clear plastic tube, taped on at strategic intervals, leading all the way down to end just below the sole of his shoe, and all the way up to disappear up the leg of his knicks. When I say small diameter I mean it can’t have been more than 2mm, and I did think at the time (once I figured out what it was for) “wow, that guy must have great control to avoid having the pressure just blow whatever attachment system he has up the top straight off.”
    I guess though if it was there for leakage rather than for actual deliberate urination (which it could have been, I didn’t stop to ask) the flow is probably going to be much slower so the pressure would be much less. I should say that I quickly moved myself ahead of this guy, just in case, and then there was a split in the bunch and I never saw him again.
    So that might be a solution for you. I must say though that you should make sure you have thick enough skin to not be offended if your riding mates send you to the back of the bunch at times, because it would probably still exit that tube at reasonable pressure. I can’t imagine having a narrow stream of high pressure urine bouncing off the road right in front of you making for a particularly pleasant riding experience!
    #713665
    QAEngineer624
    Sorry, I amended the title of
    Sorry, I amended the title of the thread and clarified the details in my initial comments.
    -QAEngineer624 aka Chris
    #713663
    QAEngineer624
    Hi Andy,
    Thanks for the
    Hi Andy,
    Thanks for the heads-up re Lemond. These lips shall never touch a peach again! I’ve got enough problems.
    I should have mentioned that it is urinary incontinence. I couldn’t imagine riding if it was faecal.
    Yes, it is humour; I’m from Canada, eh.
    -Chris
    #713661
    notfastenough
    Ewww.
    Ewww.
    #713659
    andylul
    It’s good to see you’ve not
    It’s good to see you’ve not lost your sense of humour (or is it humor)?
    You don’t mention whether it’s bladder or bowel related but I have issues related to ongoing investigations for prostatitis – I actually find the motion of cycling helps!
    Let’s hope you never have a ‘Lemond’s Bad Peach’ experience, though…
    http://www.freewheelingfrance.com/243
    Hope you get well soon
    Regards
    Andy
    #713657
    QAEngineer624
    Yup. I guess that I’ve
    Yup. I guess that I’ve already started that in a way by doing my Kegel exercises.
    They took my mojo! I still have my soul, although it’s a bit ragged. Damned if they’ll take my cycling away, too. Maybe I’ll have to visit a Lululemon store for my new kit.
    #713655
    notfastenough
    Just a thought, yoga could
    Just a thought, yoga could help build the muscles back up in that area? In the name of control and all that.
