- This topic has 115 replies, 7 voices, and was last updated 13 years, 3 months ago by
Anonymous.
January 21, 2013 at 11:10 am #17732
drheaton
Not sure if you've seen it but in case you lot haven't, I've challenged TERatcliffe this year to pick a squad of riders and try and run a 'proper' fantasy team through the season.
We'll both be blogging about it through the year and the first posts are up (/blog). Anyway, you lot are free to pick your own squads too and keep us all informed of how you're doing either on here or in the blog comments. I've set up a league and if you've got any questions, let me know.
EDIT
If you want to take part the list of rider values you'll need is here http://db.tt/1rO7IFhq and check out my post here /content/blog/74271-big-unveil for rules etc.
RUNNING UPDATE:
World Tour Points – 1037 total / 851 based on top 5 riders
Fantasy points total: 2583
TERatcliffe26
I think if your doing it as a
I think if your doing it as a draft rather than an auction per say then your way seems far too complicated and far too restrictive.I don’t quite get your first point 😕 532 riders of WT means all the others are non-WT therefore in the main will not be selected if we are sticking to WT races, so obviously if you had 15 teams you are not leaving much choice for people if its a draft and made them pick certain riders within certain price brackets etc
alright, 19 WT teams with say
alright, 19 WT teams with say 28 riders each gives a pool of 532 riders in total. In the preseason spreadsheet there are 1394, worth 9644.8 points in total.
There are 10 riders worth 30 or more, 40 worth 20-30, 261 worth 10-20.So if we say 15 teams, each with 3 star riders worth 20+ points, and 10-12 worth 10-20. with another 15 or so under 10, then the 300 points is a little generous, say 280 points to pull things down, giving a total of 4200 points used.
If we say each team must have say 3 neo pros that brings us to 30 riders per team. Careful selection of non WT riders will help too because some of the Pro level teams like Caja, Netapp etc are getting invites and turning in good performances, expanding the available pool of riders.At most I reckon you could have 20 teams, but you’d need to pull the points down, and someone would not have 3 ‘top’ level rider over 30 points, so 15 seems fair, with maybe a random pick of one of the highest value ‘star’ riders when you sign up to avoid argument, and challenge you to build a team round that high cost rider.
My current team has 1 of those 30 point + riders, 5 at 20-30, 7 at 10-20 and just 5 at 3 points only and I’m pretty happy with the breakdown. The only observation is that sprinters are pricier ‘cos these values come from the Fantasy game, not the WT points. If I picked again, I’d have a couple more 3 pointers to afford another well known sprinter. All my riders are WT, and I have a little overlap with all 3 other teams.
The other observation is that we don’t pick the actual riders in each race, so maybe it would be an idea to have 20 teams, each allowed 450 points, and 60 riders. That would use 1200 of the riders and hopefully each team would get 9 in each race, being required to declare up front. 450 points is 30 riders at 300, 30 for 150 more, averaging 5 per rider.
To sort out who gets which riders, there are loads of ways. The fairest I can think of so far is everyone is assigned a top rider. You then have a pot of ‘money’ and can bid for the next 5 riders. Winning bid signs. Then new pot of money for next 5 and so on. Giving 12 rounds of drafts in total. Maybe that’s too many, maybe 10 riders per draft for 6 rounds, or 12 for 5. First rider assigned avoids the inevitable bidding wars for Sagan or Wiggins or Cav. Or do bidding for riders over 10, and neo pros only, riders 3-10 in value sign for first offer after the bidding rounds complete.Thoughts?
drheaton
Fair point, there’s a balance
Fair point, there’s a balance to be found between having enough teams to ensure that every team isn’t full of stars and not so many teams that everyone is limited to having mostly cheap riders and can’t field full/strong teams for most races.We’ll see how this year goes (the current format doesn’t seem amazingly popular with only about 5 of us taking part) and have a look at the end of the year.
Personally I like the idea of picking a squad and running it for the whole year. It’s finding a format that works for as many people to enjoy as possible.
TERatcliffe26
I think what you would find
I think what you would find then is you are making it too restrictive, for example we’ve picked teams our teams with no other people picking and I still don’t have a full team for P-N, so I think if you tried to employ the 150 credit rule it wouldn’t work. By all means a credit limit on the overall to a degree (probably 700 id say, see why further down), as if you look at our teams, we don’t have an awful lot of stars, but we do have a fair amount of 3 credit riders, and then when you think 10 teams, thats alot of 3 credit riders gone, without there being much choice.Your talking very similar to the game I play on PROFSL, basically you have a budget and contracts. So its a bidding draft, which means you can stop as high as you want to go, and contracts can role over 2/3 years spreading cost out etc. So thats where trying to employ other limits when values are already set becomes very difficult. I think if you are using set values and say you couldn’t go over 700 credits, so you effectively couldn’t go out and have 30 guys of 25 credits it would work anyway as over 10/12 teams you would get a big enough spread of riders that people would think, oh Cancellara has gone (25 credits) your next pick, i want a classic guy who finishes high, so you go Santambrogio (8 credits) so it would all work out anyway
drheaton
If it were a proper draft you
If it were a proper draft you could credit limit it, if you end up with more than the limit after the draft then you have to release some riders and pick up whoever is free. Either that or do trades. It could be a strategy, don’t use of your limit in the draft and see who gets released after.You could even keep it persistent over years, you get to give 10 riders a three year contract, 10 a two year and the rest one year. Whoever drops out of contract ends up in the following years draft.
Also if we forced the 150 credit limit on each race it would force teams to plan and to pick riders at a variety of price points. That would hopefully encourage planning rather than trying to load up on high value stars. Anyway, the more teams there are the more the high value riders would be spread around. 150 team limit also has the benefit of meaning all scoring can be done in game 😀
Was thinking most fantasy races but maybe doing similar to this year where we do year end rankings based on accumulated World Tour points for your top 12/15 riders. Much easier to work out and covers you in case you don’t pick someone in the your squad who goes on to win something.
Just thinking aloud really, it could be fun but don’t know how many people would be interested.
TERatcliffe26
It depends what races on the
It depends what races on the actual calender you were using, as to what riders you deem valuable. The more races the more teams. But id say possibly 10-12 is about right to make it somewhat competitive. But doing a draft means you wouldn’t be credit limiteddrheaton
robdaykin wrote:Yeah, no
robdaykin wrote:Yeah, no poaching, Talansky signed with me this season :-POut of interest, thinking ahead to next year (already), how many team do you reckon we’d need to make a workable draft league? ie every rider exists once and can only sign to one team, we have a draft in the off-season then run a squad through the year in a draft league.
I was thinking somewhere between 12 and 24 but without going over the numbers (which I can’t as I’m at work at the minute) I don’t know how it’d work.
robdaykin wrote:Just looking over my spreadsheet, and after an encouraging start, there’s a huge hole with the early classics where I just have one or two riders entered per race. Seems like not many of the guys I picked for Classics are doing the early ones.Then I hit Paris Nice, and Tireno and 22 out of 27 are in there.
Seems I may have misjudged how this part of the year works with the stage races and the one days. Having said that I’ve never really bothered with any races before April/May time, so it’s all learning this year.
Next year, I think I need to review my balance of GC vs sprinters. Kittel, Cav and Appollonio aren’t enough to cover the range of races and finishes. GC riders may be better for WT over the year, but my team goals are less aligned with WT points and more crowd pleasing ones and top 20 in GC doesn’t float that many boats compared to a Sagan salute.
Maybe need to be haunting the u23 races and continental teams looking for the next fast gun.
For me this was the hardest part of picking my team, trying to get a balance between the classics, the sprints, the mountains and GC. I think I’ve done ok so far (thanks to some young GC stars) but I’m not sure I can sustain it through the year and I reckon I might have too many classics guys.
Yeah, no poaching, Talansky signed with me this season 😛Just looking over my spreadsheet, and after an encouraging start, there’s a huge hole with the early classics where I just have one or two riders entered per race. Seems like not many of the guys I picked for Classics are doing the early ones.
TERatcliffe26
drheaton wrote:Yeah, no point
drheaton wrote:Yeah, no point trying to force the purist thing on it. Pick a team per classic making whatever changes you want in between.All good makes it easier in the spreadsheet as I can do a new tab for each race then
drheaton
Yeah, no point trying to force the purist thing on it. Pick a team per classic making whatever changes you want in between.TERatcliffe26
One question, how are we
One question, how are we doing the classics? Just each race individually?drheaton
aw crap
I’m not
…aw crap :”(
I’m not entirely sure where I’ve pulled that from…
Better make it:
Roche
Westra
Kelderman
Quintana
Boonen
Bouhanni
Kittel
Tiernan-Locke
Barguilthen.
Actually, I’m not too upset because I actually really wanted Barguil in there.
TERatcliffe26
drheaton wrote:Here
He’sdrheaton wrote:HereHe’s listed on Cycling Fever and in the game.
I mean being in your team, I don’t see him on your blog or in the initial list of your riders you sent me, and he isn’t in my spreadhseet
drheaton
Here
TERatcliffe26
drheaton wrote:I’ve got quite
drheaton wrote:I’ve got quite a strong squad for PN with 13 riders in total.GC:
Roche, Westra, Kelderman, Quintana, TalanskySprinters:
Bouhanni, KittelClassics:
Boonen, Gilbert, Tiernan-LockeWildcards:
Barguil, Lutsenko, CattaneoSo… my team will be:
Roche
Westra
Kelderman
Quintana
Talansky
Bouhanni
Kittel
Tiernan-Locke
BoonenMy quandary is over whether to pick Boonen or not. It’s a toss up between him, Gilbert, Barguil and Lutsenko. Barguil/Lutsenko could do something interesting as neo-pro’s whereas Boonen/Gilbert are getting ready for the classics. Boonen won a stage last year but I don’t see him as being in the same form as last year…
Bah, Boonen it is.
Oh, and for TA I’ve currently got 9:
Cavendish, Demare, Sammy Sanchez, Jelle Vanendert, Cancellara, Vanmarcke, Nordhaug, Betancurt, Devolder.
Not nearly as strong but not terrible.
Where have you got Talansky from? 😕
