- This topic has 6 replies, 6 voices, and was last updated 13 years, 8 months ago by .
Hi,
Currently my groupset is Apex compact set 50/34T 110 165mm crankset gxp , 11-32 PG1050 cassette n Apex FD/RD
Do I need any specific request for my Red Sram 2013 5 pc groupset plus I’m planning to use Qrings n 3d crankset
One of the dealer email this info
Rotor 3D Compact 165mm Crank Set, 110 BCD
Rotor Q Rings Compact Set 50t/34t, 110 BCDSram Bottom Bracket GXP ( if you are using this bottom. Bracket with the rotor crankset then you will need a rotor bottom bracket as the SRAM GXP will not work with the rotor spindle. So this quote includes the rotor English bottom bracket)
2013 Sram Red Yaw Front Derailleur
2013 Sram Red Aero Glide Rear Derailleur
2013 Sram Red XG 1090 Powerdome Cassette (what ratio to get?)
2013 Sram Red Ergo Shifters
