Winter cycling help?
  • This topic has 10 replies, 10 voices, and was last updated 14 years ago by mr-andrew.
  • #17188
    mr-andrew
    I really want to cycle through winter this year but keep reading that I need a winter bike. Although this makes a lot o sense, it’s a reality that I can’t afford. Are there any tips to save my Ultegra groupset? I guess things like mudguards and regular chain changing make sense but am I missing anything important? Should I be riding my only bike through winter or just sitting on a trainer?
  • #705473
    mr-andrew
    Thanks for all the comments.
    Thanks for all the comments. Everything seems to point in the same direction, keep her well looked after. Sadly I don’t have space for another bike, as the SS beater seems to be a winning plan.
    #705471
    OldnSlo
    One other comment – buy some
    One other comment – buy some acf50. If this can stop a large motorcycle from rotting thru the winter then I’d reccommend for it for your road bike.
    #705469
    Gepin
    I was in the same position a
    I was in the same position a few years back. I got hold of an old 1960’s steel road frame for peanuts, turned it into a fixed wheel, raided the spare parts bin and scoured forums/flea-bay for the rest. Total cost 55GBP!
    Its used most days for commuting duties and training if the weather is totally garbage.
    As already stated cleanliness is next to godliness if any bike is to make it through the salt and grime and winter tyres and full guards are a must.
    After a so called summer riding a Carbon frame for fun and sportives and full suspension off road and for enduro events there is something very pure about getting back on the bargain basement fixie! There is nowhere to hide when the road goes up or the wind is in your face but on those quiet frosty mornings as you spin silently along on a bike that has no pretentions of granduer remember to smile at those wrecking expensive components knowing your bike cost less than a chain and cassette 😀
    #705467
    giff77
    Mudguards a definite. Weekly
    Mudguards a definite. Weekly cleaning and lubing of your chain. Regular washing if no time hose down and dry followed with a squirt of GT85/WD40 especially the moving parts – levers, callipers, mechds. Your guards though will provide plenty of protection. For tyres get a set that will prove bombproof (I go with conti 4season) and drop the pressure to about 90 or so (better traction in wet).
    #705465
    Some Fella
    There is an even easier
    There is an even easier solution. Only go out when its dry.
    I dont know where you live but even here in rainy old Manchester during the winter its as dry as many days as it is wet – especially recently with our wet summers.
    Im not one of these macho types who goes out all weathers – i only like it dry but ive noticed im getting in as much cycling in the winter as i have done in the summer.
    Probably not good advice though to someone who has a busy lifestyle and who works Mon-Fri 9 to 5 (which i dont!)
    #705463
    Coodsta
    get a cheap fixed gear? I sue
    get a cheap fixed gear? I sue one for the daily commute with full mudguards and it comes out at he weekend when it’s truly horrible weather. I only own one “proper” road bike and the just gets a set of crud catchers put on in October. As it’s steel I’m super anal about cleaning it if it gets wet, especially once they start gritting. Make sure your seatpost doesn’t seize, tape or a bit of inner tube over the clamp stops too much cack getting in there…
    I use dry lube throughout the year on my nice bike & here’s my logic, whilst wetlube does stick to the chain & it also means that grit sticks & then everything turns into a nice grinding paste & that destroys expensive alloy chainrings pretty quickly. downside is that it doesn’t stay on as long. But seeing as I clean my drivetrain after most rides that not a major issue (yes I know I’m sad). I’m pretty sure that someone, somewhere on the internet did a very unscientific study & came to the conclusion that dry lube was better… or not!
    #705461
    1. Grease everything in
    1. Grease everything in advance. I apply copper grease to all threads.
    2. Frequent washing and relubing, which is even more crucial after the council have been gritting. I found that leaving the salt residue on for a few days is worse than a month of riding in the wet. Even though I really don’t feel like washing the bike after a cold winter commute I still try to do it.
    GT85 > WD40 for cables and mech pivots.
    For the drivetrain: hot, soapy water (degreaser first with a toothbrush if caked). Dry it off then clean the chain with a squirt of WD40 on an old t-shirt. Also rub well between cassette cogs. Dry chain completely then relube (I use Green Oil).
    Replace your chain more frequently to extend the life of chainrings and cassette.
    #705459
    VecchioJo
    as above, i’ve never had a
    as above, i’ve never had a ‘winter’ bike, i just look after the bike i have, you can buy a lot of kit for your normal bike for the price of a winter bike
    #705457
    trikeman
    In addition to Dave’s
    In addition to Dave’s recommendations, you can protect your bike to keep it in ‘good health’ and here are a few tips that have kept me going though more winters than I can remember.
    Tape up the seatpost to frame cut out (stops salty water getting in the join and seizing everything up).
    Use a good car wax and cover the frame (not so much for the shiny look but to repel as much brine as possible – also makes it easier to wash down after).
    Ensure a good quality wet lube is on all mechanicals (especially the chain and clean the chain regularly).
    Clean brake surfaces regularly (brine and debris turns the brakes into grinders on the wheels).
    Keep tyre pressures up (to try to reduce the risk of p********s).
    A good GT85ing of the STI’s regularly and any bare cabling.
    Get as much reflective tape on as you feel comfortable with (gets you seen and protects on forward facing items).
    Keep lights clean and keep spare ’emergency’ lights and batteries.
    Get into a routine with rechargeable lights (put charger near where you get off bike at home so don’t forget).
    I also ensure I have clean water with me too – salty water in the mouth, or worse in the eyes, can be quickly washed out with a squirt.
    This just leaves you to be protected, the most important bit of the bike. :B
    Hope this helps.
    Regards
    Trikeman. 😉
    #705455
    dave atkinson
    you don’t *need* a winter
    you don’t *need* a winter bike, you can ride what you like. certainly i’d fit some mudguards. they’ll benefit your bike, your arse, your feet and anyone riding behind you. if you can’t fit a full mudguard take a look at sks raceblade longs or crud roadracers.
    also look at getting some winter tyres that are a bit more hardy, not many things are less fun than changing a tube in freezing rain, miles from home…
    getting your bike wet and muddy isn’t fantastic for it, but it’s road salt that does the real damage. make sure you clean it properly if there’s any salt at all on the roads.
