Is my frame cracked?
  • This topic has 14 replies, 7 voices, and was last updated 14 years ago by alston251.
  • #17064
    alston251
    I recently had a fall where my front wheel went into someone’s rear wheel.
    When i got back home i found a small mark on the top tube of the frame where i think my bars collided with the top tube. There’s no visible damage to my aluminum bars or the bar tape.
    I’m not sure if the carbon is damaged as I’ve tapped the mark and it didn’t make a different sound when compared to tapping other parts of the top tube. I’m not sure if i should be concerned.
    Any advice would be much appreciated.
    Here’s the photo:
    [url=http://www.flickr.com/photos/52000076@N04/8093860092/]http://farm9.staticflickr.com/8473/8093860092_73f662e1e1.jpg[/url]
    Cheers
Viewing 14 replies - 1 through 14 (of 14 total)
  • #704001
    alston251
    I just celled up fibre-lyte
    I just celled up fibre-lyte and am about to send them some photos of the damage. I originally wanted to contact carbon cycle repairs but it seems like nobody is answering the phone or replying the emails.
    They gave me a rough quote of about 50-60 quid which i recon is pretty decent.
    Has anyone used them before?
    #703999
    mathewshotbolt
    Crosshouses wrote:alston251
    Crosshouses wrote:
    alston251 wrote:
    Thanks for the link to Focus, i have just sent them the photo and an inquiry.
    The reply from Wiggle basically said that they can’t do anything because they don’t stock that model anymore and they have ceased to purchase from the supplier.
    Would a carbon frame repair be fine if i can’t get anything from Focus?
    No doubt a lawyer will correct me if I’m wrong, but the responsibility is with the retailer not the manufacturer re the Sale of Goods Act.
    Goods have to be ‘fit for purpose’ and a bike frame that cannot withstand a predictable impact clearly isn’t.
    frames aren’t designed to be impacted by handlebars. If you try your luck with Focus they’ll likely call you on it as they will know where the bars would have contacted.
    a mid-toptube crack in a frame with that much localisation can only be from an accident.
    Your best bet would be honesty and they will likely offer you a crash replacement for a great deal less than a new frame cost.
    #703997
    Kapelmuur
    alston251 wrote:Thanks for
    #703995
    step-hent
    Did a bit of research on carbon frame repairs recently and they seem to be fine if done properly (like any repair) – and are much more economical than a new frame! There’s a few options around. Try Fibre-Lyte – they gave me the most reasonable quote – or Carbonology (I ended up buying a repair kit from them for a small crack in a round seatstay. Haven’t tried it yet though!).
    Hope that helps.
    #703993
    alston251
    #703991
    Bird On A Bike
    Have you seen carbon fail
    Have you seen carbon fail catastrophically? I have. It’s not pretty and the resulting shards are sharp and lethal. You don’t want to be sitting astride a top tube when it does go! If you’re in any doubt, at all, don’t ride it. I’d get in touch with Focus themselves, not Wiggle. They will know the tube strength/thickness etc and will be able to assess the problem.
    I hope this helps.
    http://www.focus-bikes.com/int/en/service/contact.html
    #703989
    alston251
    It’s a Focus Cayo. Only got
    It’s a Focus Cayo. Only got it in june or something, so bit annoyed really. It was only around 20 odd mph as well. I’ve emailed Wiggle to ask about the warranty already, but no reply yet.
    #703987
    Gkam84
    What make of frame and age of
    What make of frame and age of it?
    I’d go back to the manufacturer and give them a “half truth” not that you went down or anything. Just that you hit a pot hole and you saw a crack on the frame when you got home. 😉
    You might get a nice free replacement :B
    So try that first and see, then look at other options 👿
    #703985
    alston251
    I didn’t have any car polish
    I didn’t have any car polish on hand so i tried some furniture polish then tried some Brasso.
    The area now has lost the matte finish and has gone glossy but the marks are still present. Also, you can feel the cracks coming out of the frame. So i think it’s pretty evident that the frame is cracked.
    So, should i run the risk and keep riding it or get a carbon repair or get a replacement?
    #703983
    Bobbys boys
    Car polish works fine
    #703981
    alston251
    Frame polish or furniture
    Frame polish or furniture polish?
    #703979
    Gkam84
    I would just get a cloth and
    I would just get a cloth and some polish and give it a wipe. See what happens. Just a normal wipe down.
    #703977
    alston251
    It’s a matte lacquer/ varnish
    It’s a matte lacquer/ varnish finish. No I haven’t really tried anything on it yet. I’m just trying to get as many opinions as possible first before doing anything.
    I was gonna ride it when the road rash heals up better and see if the cracks propagates.
    Cheers
    #703975
    Gkam84
    Have you tried polishing it
    Have you tried polishing it up to see if its just a mark?
    Also, what type of finish is it? To me it just looks like cracking in the finish 😕
    p.s. I like your weapon’s 😀
