Hub Query
  • This topic has 4 replies, 3 voices, and was last updated 14 years ago by TheHatter.
  • #16772
    Nevetsyarg
    I am about to get a 10spd hub and have a 9spd cassette so will this fit ok or will I need a spacer or new cassette?
    Thanks Steve
  • #699347
    TheHatter
    just for reference a
    just for reference a Campagnolo hub that takes a 10 speed cassette will also take a 9 (and an 11 for that matter).
    #699345
    cat1commuter
    You’d only need a spacer for
    You’d only need a spacer for a 7 speed cassette. 8, 9 and 10 speed cassettes all fit on the same freehub because they progressively narrower chains and spacing between sprockets.
    #699343
    Nevetsyarg
    Thanks. It’s shimano as from
    Thanks. It’s shimano as from a friend so reliable source. Good I only need a spacer.
    #699341
    cat1commuter
    Who says it is 10
    Who says it is 10 speed?
    Shimano used to make 10 speed hubs (2004 – 2007) with taller splines to prevent steel cogs biting into aluminium freehub bodies. It didn’t catch on, and they reverted to the shallower splines. So all Shimano / SRAM freehub bodies are now the same. (Unless you go to 11 speed Dura Ace, which, I think, just needs a spacer to be compatible with 8/9/10 speed cassettes.)
    So, no problem (unless your hub or cassette is Campagnolo, which is another story).
