Rest Day Transfers?
  • This topic has 11 replies, 6 voices, and was last updated 14 years ago by memories of meseeuw.
  • #16665
    memories of meseeuw
    1) If I take one spare transfer into the rest day will I come out the other side with 5 transfers or lose it and just have the usual 4?
    2) If I do take five transfers into stage 10 (Vuelta) and only use 2 will I still have 5 again for the TT (stage 11) or lose the saved transfers and only have 2?
    Anyone able to confirm the situation please?
  • #697125
    memories of meseeuw
    TERatcliffe26 wrote:memories
    memories of meseeuw wrote:
    Gkam84 wrote:
    Yeah, if you make changes today, you can roll 2 over and have 4 for the ITT
    And so just to clarify… if you then only use 2 for the ITT you’ll have 4 coming out of the other side, right?
    Yes, if you continued to use just 2 per stage, you would have the option to use 4 until you use more than 2 (if that makes sense?)
    My plan is to use 3 for the ITT, so i have 3 for stage after that
    Ok thanks. That’s as I understood it then, so that’ a relief. I used 2 today in ITT anitcipation so that I only need to use 2 more for ITT and then still have 4 out the other side.
    #697123
    TERatcliffe26
    memories of meseeuw
    #697121
    memories of meseeuw
    Gkam84 wrote:Yeah, if you
    #697119
    enrique
    Gkam84 wrote:The MOST you can
    Gkam84 wrote:
    The MOST you can roll over is 2.
    Next year I hope we get to roll over up to 4. Or maybe all we want! 🙂
    Sometimes, like for the rest day, you’re forced to use 2 so they won’t go to waste. It’d be cool to be able to bank them and use them at will instead of losing them because you don’t use them…
    #697117
    Gkam84
    #697115
    drheaton
    So, if I make no rest day
    So, if I make no rest day transfers only 2 of the 4 will roll forward giving a maximum possible transfers for the ITT of 4. So, I can use up to two rest day transfers and still have 4 for the ITT.
    That makes sense I guess.
    #697113
    Gkam84
    So the most you can have any normal day is 4, on rest days, If you make no changes, You will still only roll 2 over. So today and tomorrow you could have up to 6 transfers the rolled over 2 + 4 for the rest day.
    If you choose to make any number of changes. You will only have 4 on Tuesday for Wednesday’s ITT
    #697111
    drheaton
    So, Gkam/Dave, if I don’t use
    So, Gkam/Dave, if I don’t use any of my four rest day transfers do I
    a) carry over all four to use, plus two from Tuesday thus having 6 for the ITT
    b) carry over four but cap out at four so I can only use a max of four for Tuesdays ITT
    Just want the official line before I start overhauling my team.
    #697109
    Lost faith in the brand
    ignore
    ignore
    #697107
    memories of meseeuw
    Ok, thanks.
    Ok, thanks.
    #697105
    Gkam84
    The most you can roll over is
    The most you can roll over is 2, So on a rest day you can have 6 and then any other time its 4
