Single speeding an old road bike, help please…
  • #16638
    _Karlos_
    It’s a little project I’ve been meaning to get round to for a while, and with the onset of winter (sorry) I thought I’d get round to it.
    I basically have a 1999 Dawes Giro, which is 7spd and has a screw on freewheel type hub.
    What will I need to make the conversion?
    The bike will really only be used for commuting, the commute is all flat. So, ratios wise (I really know very little about this) what should I looking at?
    I’m quite a strong cyclist, but then sometimes in the morning I can’t be arsed to put much effort in, so don’t want something that will be a nightmare to push if this is the case.
    Thanks in advance. 😕
    :B
  • #696657
    charliemac74
    Check out Sheldon Brown’s
    Check out Sheldon Brown’s site mentioned above, I converted an old frame with vertical dropouts and a cracked gear hanger using his tip for cutting down the axle length. Using that fix and a half link I sorted an fixed wheel with limited fuss that could take a range of ratio’s.
    #696655
    Gkam84
    I have to agree with Dave
    I have to agree with Dave about the ENO hub, thats why i’m taking his s/s off his hands.
    But if you don’t have the cash to splash on something like that. Then something like this would do you fine without changing much apart from cassette and chainset 😉
    http://www.ebay.co.uk/itm/DMR-Single-Speed-Convertor-Tensioner-STS-Twin-Kit-New-Chain-Black-/261073025649?_trksid=p3284.m263&_trkparms=algo%3DSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BIEW%252BFICS%252BUFI%26otn%3D21%26pmod%3D360480713193%26ps%3D54#ht_518wt_1186
    #696653
    russyparkin
    dave_atkinson wrote:best way
    best way to get good chain tension on vertical dropouts is with an ENO hub – not cheap though :?
    yes agreed with this, made by white industries. you wont go far wrong contacting ‘charlie the bikemonger’
    very helpful
    #696651
    dave atkinson
    best way to get good chain tension on vertical dropouts is with an ENO hub – not cheap though 😕
    #696649
    Raleigh
    Ratios, 48×15 will probably
    Ratios, 48×15 will probably be good for flat commuting, 42 for rolling, you’ll need to be very careful about chainline and tension.
    Anything less, and you’ll spin out on tiny descents, anything more, and if there’s a headwind, you’ll be overgeared.
    You could just buy a track wheel off planet x, then the conversion would be easier.
    #696647
    Raleigh
    Will be difficult to get the
    Will be difficult to get the right chain tension on verts, may need a tensioner, or a different frame.
    #696645
    giff77
    Hey Karlos. Shimano do a
    Hey Karlos. Shimano do a freewheel single speed cog. You can get on CRC for £22 I think. I use the 17t but I have a couple of hills on my commute. You’ll need to pick up a single speed chain. I recommend the small chain ring (I’m assuming it’s a 38 and also helps with the chainline) Also if you have skewers ditch the rear ones for nuts. And that will stop the rear wheel slipping. Either that or get a chain tensioner. Otherwise you will be retesioning the chain every few days. Hope that helps
    Giff
    #696643
    _Karlos_
    Cheers.
    Sorry forgot to
    Cheers.
    Sorry forgot to mention, it has vertical dropouts.
    #696641
    Raleigh
    This is pretty good
    This is pretty good stuff;
    http://sheldonbrown.com/singlespeed.html
    #696639
    dave atkinson
    does it have sloping slot
    does it have sloping slot dropouts?
