- This topic has 18 replies, 12 voices, and was last updated 14 years, 6 months ago by
wyadvd.
April 30, 2012 at 7:05 pm #15694
ryewheeler
Can anyone recommend a waterproof jacket that really is just that – waterproof. Not just for 10 minutes but for an hour or so. Have tried 4 jackets claiming to be such (admittedly not top dollar) which are about as useful as a chocolate teapot and have now had enough.
wyadvd
this looks like the mutts
this looks like the mutts nutts:complete with very sturdy looking chin straps for when there’s a real south westerly:
http://www.ebay.co.uk/itm/Grundens-Sandhamn-21-Souwester-/110808153133?var=#vi-content
arowland
Waterproof cape and
Waterproof cape and sou’wester. Can’t beat them. Don’t use a hood because they stop the moist air venting out through the neck.
Stiff sou’westers are much better than the floppy, foldable sort, but harder to stow away. And unfortunately, getting rather hard to get hold of these days. Even ships chandlers don’t stock them any more.wyadvd
I am very happy with my
I am very happy with my endura windchill jacket. Been through 3 winters now on a 30 mile round trip commute. Pretty much totally water proof on the front , rounaix Lycra on the rear. Very breathable as a result. If you are sensible and ride mudguards at this time of year, your back honestly stays dry even in prolonged downpours ( I know it’s counterintuitive). Until you use a jacket like this in the rain you won’t believe it. It has side vents and fits like a proper jersey. With a craft singlet underneath and bib shorts it’s good for strenuous riding up to about 16c too, so it stays on all winter, it’s all I need! Try it only 75 quids
Other than that I can positively recommend the range of waterproof jackets made by an American company called ” showers pass” available from mosquito bikes and urban hunter but also importable from the bicycle hub. In the states they are known as ” the best ” breathable waterproofs.russyparkin
erm koo bikes on ebay, its
erm koo bikes on ebay, its wearable off the bike (i went for the purple) break the mould and all that! its really really good.put it this way i live in plymouth, my play ground is dartmoor and i have 100% faith it will get me through anything with varying levels of sports wool underneathkeef66
I have a Gore Path jacket.
I have a Gore Path jacket. Material is Goretex Paclite so it’s pretty thin; If I roll it carefully I can fit it in a jersey pocket when not required. It is completely wind and waterproof. It is also very breathable; after a couple of hours the only points where moisture is visible on the inside are along the taped seams. It is apparent that the rest of the fabric is allowing a lot of water vapour out.ryewheeler
Thanks russyparkin. Have to
Thanks russyparkin. Have to say ‘Surface Pertex’ is a new one on me.. Where did you get it from??ryewheeler
Thanks Slowclimb. Forgive my
Thanks Slowclimb. Forgive my cynicism but does breathable also = waterproof? i know a couple of people who use this jacket who say that it’s OK for light showers and short rides but after that you do get wet. Thanks for your input. I do get the impression that I’m on a grail-quest here which even large quantities of cash won’t sort – the Gore Oxygen ain’t cheap. Thanks once again for your advice.slowclimb
Sorted:
Sorted: http://www.gore-tex.co.uk/product/gore-bike-wear-oxygen-gt-as-jacket/1313877796061/
Most breathable fabric I’ve ever used.russyparkin
i rode in a surface pertex
i rode in a surface pertex recently on two big rides (77) (89) miles. the body and arms kept me completely dry but the shoulder seam let a small amount in. reckon i did at least 40 miles in rain (ranging from constant spitting to big showers) worked for me, stylish-ish and around £40. didnt boil on the climbs either, underneath had a torm merino jersey and base layer. warm enough all ride etcryewheeler
Dear All, Many thanks for
Dear All, Many thanks for your input. It does seem to be a tricky one. I don’t mind riding for a few hours, getting soaked and then coming back to a good shower. My problem is that I do a ride/train/ride commute. Ride for an hour/on train for an hour/ride for 10 mins. If you get soaked on the first ride, sitting on the train is most unpleasant. I hear what zzgavin says re: needing to spend 200+, which I’d like to avoid but starting to resign myself to it. I have an Altura which frankly is good for about half an hour and then is next to useless. So if anybody else has got a breakthrough idea I’d welcome it. Cheerszzgavin
A combination of a sportful
A combination of a sportful hotpack4 and a gore windstopper ozon jersey did well in the rain on Sunday. I was damp, but still warm after 4 hours. To get really waterproof you need to be at the 200+ end of the market, I think. I’d rather be a bit damp, but warm.
The sportful hotpack4 is great, the water really does bead off it, I got it for 50 from sigma, but they seem to have sold out now. I really like the gore windstopper ozone jersey too, I’ve worn it much of the winter and spring.Sadly Biggins
Thanks Trikeman – just me
Thanks Trikeman – just me twisting your words out of context. Worryingly (for me) I’m not a tabloid journalist either…roly
altura nightvison for me too.
altura nightvison for me too. I seem to survive without getting rain down the neck. Also enough zippable vents to allow air movement. Had it two years and the only damge is on of the pockets has gone through. Definitely won’t fit in the back pocket of a jersey though, and way too hot abouve 15 degrees.trikeman
Brilliant!!!!
I could never
Brilliant!!!!=D>I could never be a tabloid journalist for a living. I would end up being locked up for something I never meant.
Thanks for pointing out my blunder. 🙂 It does come with age though.
Regards
Trikeman. 😉
Sadly Biggins
trikeman wrote:I don’t get
trikeman wrote:I don’t get really wet from heat (vented out the loose bottom)
That sounds quite handy. Does it come with age? 😀 -
