- This topic has 12 replies, 8 voices, and was last updated 14 years, 8 months ago by
notfastenough.
February 29, 2012 at 6:55 am #15228
MickeyBlueEyes
Would you ever consider, or is it even possible to swap the front 50 of a compact to a 53, therefore running 53/34 with 11-28 rear? Max top end and min bottom end?
notfastenough
Ah right, cheers.
Maybe I’m
Ah right, cheers.Maybe I’m not much of a descender, but I think 50-34 and 11-25 is more than enough.
step-hent wrote:Depends where
step-hent wrote:Depends where you ride, no? I have spun out my 50×11 on long mountain descents in Spain, but would have been grovelling even more than I already was if I’d had a 38 tooth inner chainring (the smallest possible for a standard, rather than compact, setup) instead of my 34 for the climbs.
No, I’d say it depends how you ride.Even I could probably spin out on 50×11 if I found a descent long and steep enough but that’s not the same as it being inadequate for my (or the OP’s) purpose.
If you’re honestly strong enough to push 50×11 and be looking for more you probably won’t need a 34t inner ring for anywhere bar the Angliru. As an aside, this article says David Millar ran an Apex 11-36t cassette with large inner in last year’s Giro (IIRC 42T is the smallest in the elliptical chainrings he likes).
giff77
@ notfastenough – here’s the
@ notfastenough – here’s the link 😉 http://m.road.cc/content/forum/48334-53-34Back to the subject in hand – that’s a huge jump 19t. The norm is 16t. You would need a rear mech with a long cage to help the shifting as well. Why not just switch to a SD if you are wanting a bit more power in the big ring. Though you will defo feel the hills on a 38 if only used to a 34. If you go to Sheldon Brown you will find tables there with gain ratios etc and see if running a 53:11 is better than a 50:11
giff77
SideBurn
Page 7 of what?
Page 7 of
Page 7 of what?Page 7 of this forum; but it will soon be page 8! Have look at the bottom of the first page and there are page numbers…
step-hent
Simon E wrote:50×11 not big
Simon E wrote:50×11 not big enough?You must have been out when Team Sky came round to your house with a fat contract.
For my normal riding I don’t need the range that the OP is looking for, but if I was riding in the mountains a lot then I’d seriously consider a triple in order to get the range…
You
notfastenough
page 7 of what?
page 7 of what?MickeyBlueEyes
SideBurn wrote:Have a look at
SideBurn wrote:Have a look at ’53 34?’ on page 7Whoops, note to self, search discreetly for answers to my minds silly questions before asking the forum……
Mr Will
Max top end, Min bottom end,
Max top end, Min bottom end, Great big holes between gears.Seriously though, why would you want to? If you are strong enough to push a 53/11 then you will not need a 34/28 for anything this side of a brick wall!
…And if by some miracle you actually do need both, then a triple would be a far better way to go.
SideBurn
Have a look at ’53 34?’ on page 7Anonymous
I don’t think you will find a
I don’t think you will find a derailleur that will support a 19T different between the chainrings. And while I’ve never tried it I’ve always been told that 53T compact chainrings aren’t stiff enough and shifting will suffer. -
