- This topic has 6 replies, 6 voices, and was last updated 14 years, 8 months ago by .
Ok. so I have this old Binachi Reparto Corse L Lite Alloy
Currently running with a 105 crank 53/42
After some consideration I’ve decided to get this crank: Shimano Sora Compact Chainset 3450Thing is I just realized that I will probably need to replace the Bottom Bracket as the old 105 crank (probably) uses a square taper and the Sora needs only the bottom bracket cups
Questions:
Am I correct in assuming that I need to change the bottom bracket?
If so, what BB should I get, how do I know what thread (english, italian) do I need?
