- This topic has 1 reply, 1 voice, and was last updated 14 years, 8 months ago by .
All parts from my now broken commuter – I snapped the frame and without the original receipt (lost) I can’t claim under warranty…
Alfine 8, 16 hole black hub with 18t rear sprocket, built onto a DT Swiss Maddux disc rim. Complete with 160mm disc, gear cables & shifter with slight crazing to the clear shifter cover which was there from new and never got sorted.
Also Truvativ GXP cranks with 42t chainring which is showing signs of wear. Some light marks to crank arms but bearing surfaces, splines and threads all good and a set of Avid Juicy 3 brakes, in good working order with oe hoses (hence surface rust on unions), 160mm rotors and all bolts / mounting washers.Offers on £220 delivered in the UK – may split.
Plenty of pics available here http://www.flickr.com/photos/81846168@N00/sets/72157628650970157/
patrick.rennison@gmail.com or 07917 746257
Thanks
