First time Road-biking. What clothing?
  • #14673
    kupepe
    Goodmonring and Merry Christmas.
    I have bought my forst road bike and after deciding on SPD pedals and shoes I am looking to buy my clothes. I am kinda lost since the layers concepts give you so many solutions that it is troubling. Moreover, begging road biking its kinda expensive, since you need gear besides the bike, so I am in a budget.
    I have selected
    Tights:
    http://www.chainreactioncycles.com/Models.aspx?ModelID=34857
    L/S Base layer:
    http://www.chainreactioncycles.com/Models.aspx?ModelID=26756
    I got a budget for one more item to help me stay warm.
    I am cycling by the sea, so there will be mild winds, under temperatures 10-22 Celsious.
    Should I go for a long sleeve jersey? What caracteristics should it have? Or a winter Jersey is better?
    I would really like some input.
    Merry Christmas
  • #659577
    No-Chain
    This is the best all round
    This is the best all round bit of kit I’ve had in 35yrs cycling all weathers:
    http://bikemagic.com/gear/reviews/bontrager-rl-thermal-soft-shell-jacket-review.html
    It is practically waterproof but feels like a jersey and is good for temperatures from below zero to about 16degrees C without getting too hot.
    Other advice would be shorts and leg warmers -Don’t go overboard on the shorts and buy Assos or something – I like Lusso or Endura. They all tear should you have a tumble but you won’t need a lottery win to replace them!!
    Then a good base layer under a jersey of your choice. Again my preference for fit, comfort and price is a DHB item from Wiggle in either short or long sleeve.
    Good luck and just pedal!!
    #659575
    kupepe
    Thanx for the advice people
    Thanx for the advice people … MErry christmas
    #659573
    nick_rearden
    In those temperatures I’d
    In those temperatures I’d select from the following according to the day:
    3/4 length bib-shorts
    short sleeve base layer
    short sleeve jersey
    arm warmers
    thin windproof shell or gilet small enough for jersey pocket
    The advice about several thinner layers giving you more options is good.
    Don’t know far you are from a bike shop but a lot of them will be holding sales at this time of year, as will the big mailorder houses but the reason I would advise on an actual bike shop at this stage is you can try on several options and seek the advice of other local cyclists who are experienced in the climate. Shops tend to stock clothing they like wearing.
    Final piece of advice; if you ride away from your house feeling warm enough you’re probably going to feel overdressed within a few kilometres.
    #659571
    Giant Rob
    Even on the coldest day you
    Even on the coldest day you will find you warm up. The tights look good but I wear a long sleeve top with a half zip. The zip comes down to just below your chest. You can unzip it when you are hot and zip it up again when you cool down. My feet always get cold in the winter so I use overshoes. Not sure if you need these yet so wait until you find you get cold feet. Good luck!
    #659569
    Tony Farrelly
    Yes I reckon a softshell
    Yes I reckon a softshell would be too warm – on all but the coldest days I find mine too warm here in the UK with all but a short sleeved base layer. We’ve had a mild winter so far here in the UK, but most days I’ve ridden in a merino base + either bib longs or bibshorts and leg warmers, short sleeved jersey and either road.cc armwarmers or some Craft ones. In the wet I’ve maybe usually foregone one top layer and added a breathable rainshell.
    Given where you are and your likely riding temperatures I’d suggest short-sleeved base/jersey combo matched up with some armwarmers and a gilet with a windproof front would be the way to go on top – especially if you don’t have to worry about rain.
    Those Endura tights are good too, but I’m wondering whether they might be too warm for you in Greece (maybe not, to some degree it’s all relative) but Endura are based in Scotland where it’s properly cold so their kit is warm – certainly you won’t need to worry about getting cold in them.
    #659567
    PeteH
    merino is a good choice. If
    merino is a good choice. If it were me I’d probably go for something lightweight and windproof. Maybe a gilet even?
    Heck, if it were me in those temperatures I’d be in bibshorts and summer jersey!
    Seriously, have a look at some of the kit reviewed on this site to get an idea of what your options are, and the principle of many thin layers is a good one – I’m in the UK and generally wear the same clothing throughout autumn/winter/spring, just in different combinations.
    #659565
    kupepe
    Well,
    I guess I am cycling
    Well,
    I guess I am cycling in a warm environment, since I am living in Greece.
    I have chosen a merinos long sleeved base layer for upper body.
    I am confused on what to buy for over it? Softshell jacket to heavy? A long sleeve jersey is good combined with the posted baselayer?
    #659563
    seabass89
    Hey,
    So you’re cycling in
    Hey,
    So you’re cycling in 10-22 degrees. That is quite warm in my book.
    There is a couple of key points to keep warm:
    1. Heat travels UP your body (from feet to head) So if it its cold its important to wear a hat, and layers on your upper body as this is where your body heat will escape.
    2. Always have a WOOL inner layer. Wool will stay warm even if you get wet. Cotton or technical materials will not.
    With that in mind you should have some tights with some padding as it just is a lot more comfortable when you’re road cycling.
    It depends a little on what you have allready, really :S
