stem size
  • #14626
    baz69
    have a cube attempt frame ,but how do i know which stem size to go for 100 110 120 ?,iam 5 9″ the frame size is a 53cm ,thanks.
  • #659001
    PeteH
    first thing is that it makes
    first thing is that it makes a big difference. I not long got a secondhand bike and although the frame was the right size I constantly felt that I was stretching for the bars – I crudely measured the handlebar at about an inch and a half further away than I’d like. Turns out it had a stem of 11cm.
    I basically got a cheap noname 7cm stem (so pretty much at the other extreme) mail order, and just swapped them over. Really, I bought it just to experiment and it was sufficiently cheap that I could just chuck it away.
    But it was good to have for comparison and as soon as some money becomes available I might buy a better stem (carbon even?) at about 8cm, which should be ideal.
    I agree with Hatter – if you can get your LBS to indulge you, they’re bound to have different stem lengths in stock for you to experiment.
    #658999
    TheHatter
    If you’re getting it from a
    If you’re getting it from a shop then get them to advise – ideally by trying out different combos. Otherwise have a look here when I asked a similar question [url]http://road.cc/content/forum/26235-does-size-matter[/url]
