53 34?
  • #14542
    Cooks
    Is such a thing possible? Just the idea popped into my head. Would it take just a bit of fiddling with the front mech, or, a re designed front mech cage?
  • #658005
    According to CTT gear
    According to CTT gear table
    53×12 = 117.4″
    50×12 = 110.7″
    I can’t see it’s worth the bother.
    And if you think you need a 11-tooth small cog on your cassette you should call Dave Brailsford 😉
    #658003
    Winton
    I know they’re not for
    I know they’re not for everyone but Rotor do a 52/36 set f Q Rings with BCD110. I’ve always thought them a good compromise.
    #658001
    Tony Farrelly
    yes I used to have a Dura Ace
    yes I used to have a Dura Ace racing triple with the same 53 42 30 set up, it was great… shame it about the Octalink bit though.
    #657999
    SideBurn
    Or to embelish my negative
    Or to embelish my negative sounding ‘Why?’ I have a Campagnolo Chorus triple 53,42,30 on my Cyclo cross bike with a standard Campagnolo Record titanium front changer and a Campagnolo rear mech. This works well…I do not understand what you would achieve with such a big difference between two rings. The triple allows me to fly up and down hills…result!I think the big difference between two cogs will cause problems 😕
    #657997
    Cooks
    No real reason other than it
    No real reason other than it just popped into my head. I guess the 19tooth shift part would be the kicker…
    #657995
    A 19-tooth shift? Eek!
    Not
    Not sure you’d find two compatible chainrings, as BCD (bolt diameter) would differ. Have a look at SJS Cycles’ website stock, they list lots of chainrings.
    Or run 53/39 with a wider spaced cassette e.g. the new SRAM Apex?
    #657993
    the_mikey
    Use a long cage MTB
    Use a long cage MTB derailleur or anything that works with a triple, those can handle 30/39/52, 53/34 isn’t so outlandish.
    #657991
    Fringe
    think the maximum is a step
    think the maximum is a step up of 16, hence 34/50..but give it a go if you’ve got the parts..
    #657989
    SideBurn
    One question….Why?
    One question….Why?
