curling your toes !! riding with toes tending to curl up ….
  • This topic has 4 replies, 2 voices, and was last updated 15 years ago by ashy_2002.
  • #14254
    ashy_2002
    Ok then I have a problem .. Hmmm which I have overcome somewhat to a point .. BUT other peoples experiences / solutions would be appreciated :
    When I pedal I tend to curl my toes upwards therefore causing pressure on the big toes especially… this has now caused my right toe on the left side to be partly numb..
    I have overcome this somewhat by using triathalon shoes with mesh tops such as pearl izumi (more room) .
    Using normal SIDI shoes etc.. I have had to use a very slim shoe insole to cope with the toe curl… to give more toe room !!!..
    I also suffer some hot foot /foot swelling for the first 10 miles of a ride… this goes away as the ride goes on…
    Note I always keep my toenails clean and clipped
    I use very good wide platform pedals in Miche range…
    Any advice to help or share the problems encountered ? comments appreciated…
  • #655007
    ashy_2002
    Nope … my current setting
    Nope … my current setting is just behind the “ball” joint…………..
    #655005
    ALIHISGREAT
    maybe incorrect cleat
    maybe incorrect cleat position? -> it could be too far forward putting upward pressure on your toes?
    #655003
    ashy_2002
    Nope not Hammer toe…. the
    Nope not Hammer toe…. the problem only really seems to affect my big toes and when using shoes without room I do find that the skin under the toenail can turn white at the tip (pressure) … a bit weird I know .
    Went to the docs about the slight numbness in the left side of my big toe, this numbness was after a san fran to LA ride a few years ago and its never gone away … he put it getting OLDER…. BUT it does seem to be a result of pressure …
    my feet otherwise are in good shape .
    But thought I’d put it our there is anyone else has a similar issue…
    #655001
    ALIHISGREAT
    just to be clear… we’re not
    just to be clear… we’re not talking about hammer toe?
    [url]http://en.wikipedia.org/wiki/Hammer_toe[/url]
